Author Topic: Re: How to setup a Custom WAP page  (Read 14101 times)
Online Weather Display
  • Davis VP2
    • Weather Display
« on: October 23, 2004, 07:01:11 PM »
excellent work!
i am very pleased to see someone take the time and effor to put up a help/tip
thanks!
the tag to show the time stamped graph is:
%filenamewapgraph%
i will have to add a station name tag
bristolwx
  • Guest
« Reply #1 on: October 23, 2004, 07:14:19 PM »
[gratuitous plug]
my custom WAP data is at http://www.martynhicks.co.uk/weather/wap/index.wml
it would be nice to get reports from others that have accessed it to make sure it works ok - it does for me on my Sony Ericsson T610
[/gratuitous plug]
Offline TNETWeather
  • Kevin Reed (KrelvinAZ)
  • Gremlins are at work...
  • Mesa, AZ
« Reply #2 on: October 23, 2004, 09:16:22 PM »
A snapshot off my phone of your page is attached....
Offline carterlake
  • Tom Chaplin
  • Carter Lake, Iowa USA
    • Carter Lake, Iowa Weather
« Reply #3 on: October 23, 2004, 09:37:53 PM »
For those with WAP pages.... this is a great emulator.
http://www.gelon.net/
Offline Ciemon
  • Salisbury, UK
« Reply #4 on: October 30, 2004, 08:52:11 PM »
Chaps...
Is there a way to set a different location for the wap page to be stored?
I'm hosting my site on the same PC as the weather station (so no ftp required) and I want the wap page to go into ../wap
Thanks.. Ciemon
  • Davis VP2
    • Weather Display
« Reply #5 on: November 02, 2004, 01:39:27 AM »
in 10.18y, ready soon, you can set to use a different director for the wap file
Offline Ciemon
  • Salisbury, UK
« Reply #6 on: November 02, 2004, 07:06:08 AM »
Thanks Windy,
Same question in two different places :|
  • Davis VP2
    • Weather Display
« Reply #7 on: November 02, 2004, 07:12:27 AM »
hi
so is it working?
(as I did not have time to actualy test)
Offline Ciemon
  • Salisbury, UK
« Reply #8 on: November 02, 2004, 07:20:31 AM »
I've not downloaded it...
I'll go and have a hunt then let you know :)
Offline Ciemon
  • Salisbury, UK
« Reply #9 on: November 02, 2004, 12:33:32 PM »
It would appear that it doesn't work.
Whilst all the required input options are there, the information doesn't appear to be saved.
After setting up the wap page's directory, and ok'ing the page, then re-opening it, the previously setup options are back to the default of nothing.
Not my best description ever, hope it's enough.
Thanks..
  • Davis VP2
    • Weather Display
« Reply #10 on: November 04, 2004, 02:13:18 AM »
hi
good news
i found some time to fix this
download a new zip version in about 1 hour from now, or when the download page says the time has changed
(and then reset up)
  • Davis VP2
    • Weather Display
« Reply #11 on: November 06, 2004, 08:28:52 AM »
hi
try this version
it should be ok for this different wap location ( i tested)
http://www.tokaanuskihire.co.nz/WeatherD.zip
(i.e unzip to where you have wd installed, but exit wd first)
