I update to 37r build 54 in middle of last week and since then the videos created are going very fast, according to the moviemaker log it creating them at 30 fps.
I have the setting in WD set at 6 fps, I changed this to 5 and saved but this made no difference .
I noticed this morning that the moviemaker version has changed to 6.2, I then put the previous version 5.9 on from my last backup and the speed is back to normal, so the frame setting in WD is not being seen by moviemaker 6.2.
I have also noted that the all day date stamped videos name has reverted back to alldaymovie2232013 with 6.2 was 20130319dayvideo with 5.9
has this been noted by anyone else or is it just me
I had the same problem with alldaymovie. Read the last few posts on this thread. It’s something to do with the old webcam settings. Download the latest version of moviemaker and all should be well.
My files do play a lot faster than they used to, but I don’t really mind that too much as I’m using ten second images and the videos do last a while.
I’ve just checked my files and I can confirm that my version is also creating videos in the format alldaymovieddmyyyy.mp4. The program hasn’t created videos for the last two days. I am using the latest version of moviemaker.exe.
As for the speed of the videos, my hourly video has decreased in time from over 20 seconds to 9. My yesterday file used to be around 7 minutes, it is now just over 3.
The movie parameters cannot be adjusted in the “new all day video setup” area, but any changes made in the registry settings are shown in the screen, but so far I can’t see any affect on the movies.
a “delay between frames” has appeared and so far doesn’t seem to have any affect
I am helping out on a school camp today
I will look into why the set frame rate is not working with the updated component when I get home tonight
(lots of things were changed with the updating the component, I spent a long time getting the code converted (hoping there would be some good benefits))
Hi Georg,
You seem to have a good set-up there which definitely runs better and clearer than mine.
I have tried a large number of set-up variations, but as much as I have tried, mine is not as clear as yours.
Would you mind sharing your set-up please?
My time lapse can be found at : www.cotswold-weather.co.uk/time-lapse.php and it’s definitely been better quality in the past.
I am using the very latest version of moviemaker (6.4) and version 10.2 of the webcam capturing software… all the latest, therefore it must be my set-up that is letting me down.
best regards
Steve
I see now that the bit rate has not been used with this new component update
I see via the documentation how to implement it
I will as k the author for the best way to do it
