gauge titles
Is there a way to make the text headings in the gauges (temperature, humidity etc.) a slightly larger font or make bold?
I have looked through all the css and other settings but cannot find a way to do this.
Am I missing something obvious?
Thanks for any guidance
No, you are not missing anything obvious. The text size is set in the steelseries library, if you want to alter it, then you will have to modify the library - the source is in the scripts\src folder.
Thanks Mark
