Author Topic: Sunrise/Sunset script  (Read 31259 times)
Offline jmcmurry
  • Jim McMurry
  • Mauston, WI, USA
  • Win XP
  • Firefox 18.0
    • Juneau County Weather
Re: Sunrise/Sunset script
« Reply #15 on: January 31, 2013, 03:24:06 PM »
Jerry,
It looks like you'll need to tweak the css in the code ... I had to do some funky stuff to get everything to display the way I wanted.  It looks like Rick's worked out ok.
- Jim
Forum Search and Google can be your best friends
Offline rrrick8
  • Danville, Illinois
  • Win 7/Srvr 2008R2
  • Firefox 18.0
    • Vermilion County Weather
« Reply #16 on: January 31, 2013, 03:33:44 PM »
Jerry,
- Jim
Yes, I had to move some things a bit and changed a few colors to match my site.
Rick
EMA Severe Weather Manager
CWOP-CW9931 -  KILDANVI5
Offline jahuff
  • Northern New Hampshire, USA
  • Win NT 6.2
  • MS IE 10.0
    • Weather Data Pittsburg, NH
« Reply #17 on: January 31, 2013, 04:12:47 PM »
Hi Jerry,
I am still not getting the graph, I just get the placeholder "graph". I can't seem to get the code to work. Could you post your code.
John
Online Martyn
  • Davis VP2+ FARS/solar/UV
  • Bristol, UK
  • Win 7/Srvr 2008R2
  • Firefox 17.0
    • Horfield/Filton, Bristol, UK weather station
« Reply #18 on: January 31, 2013, 05:24:22 PM »
I have it on my site now with code tweaks to fit my site colours/ layout, including rotating the chart to show daylight hours starting at the top (zero degrees) and adding the actual hours to the chart as well as percentages. I didn't get the chart to show until I put the Google API chart code all on one line without spaces.
« Last Edit: January 31, 2013, 11:50:12 PM by Martyn »
Martyn,
Bristol, UK
Twitter: https://twitter.com/HorfieldWeather
FB: https://www.facebook.com/bristolweather
CWOP: CW2888
WU: IBRISTOL3
Offline jahuff
  • Win NT 6.2
  • MS IE 10.0
« Reply #19 on: January 31, 2013, 06:19:54 PM »
Hi Martyn,
Thanks for the info. I got it working after several attempts, I just need to adjust things now.
Thanks again,
John
Offline gwwilk
  • Lincoln, NE
  • Win 7/Srvr 2008R2
  • Chrome 24.0.1312.56
    • Southeast Lincoln Weather
« Reply #20 on: January 31, 2013, 06:26:45 PM »
Jerry,
- Jim
You are so right, Jim!  I think I've got it the way I want it now.  My code allows for style switching, but it's a bit messy:
Code: [Select]
<p class="sideBarTitle"><?php langtrans('Daylight Hours'); ?></p>
    <div class="sideBarText" style="font-weight:lighter; font-size: 6.5pt; text-align: center; margin-bottom:-4px">
          <?php
//Make piechart
$testtime substr($hoursofpossibledaylight,0,2);
$testminute substr($hoursofpossibledaylight,-2,2);
$testminute=$testminute/60;
$testresult=$testtime+$testminute;
$testljus=round(($testresult/24)*100,1);
$testmorker=100-$testljus;
            <span class="thisPage" style="position: relative; font-weight:lighter">
          <?php
            $time_arr
explode(':'$hoursofpossibledaylight2);
            echo (int)
$time_arr[0] . " hrs " . (int)$time_arr[1] . " min";
            echo
'<br/>of Daylight Today<br/>';
            </span>
            <img style="margin-top:4px" src="http://chart.apis.google.com/chart?chs=100x60&amp;chma=0,0,0,0&amp;chd=t:<?php echo $testljus;?>,<?php echo $testmorker;?>&amp;cht=p3&amp;chp=1.6&amp;chf=bg,s,CCCCCC&amp;chco=FFD700,000000" alt="graph"/>
            <br />
            <span style="position:relative; float:left; margin-top:-36px; margin-left:20px; font-weight:lighter; color:#000000">        <!-- was -5 -->
                <?php echo $testljus "%"?>
            </span>
            <span style=" position:relative; float:right; margin-top:-36px; margin-right:20px; font-weight:lighter; color:#FFFFFF">      <!-- was 5 -->
                <?php echo $testmorker "%"?>
            </span>
            <span class="thisPage" style=" position:relative; font-weight:lighter; top:-8px">
        <?php
echo '<br/>Which is <br/>';
$time_arr explode(':'$changeinday);
            if (
substr($time_arr[0],0,1) != "-") {         // -0 when getting shorter
echo (int)$time_arr[1] . " min Longer";
            } else {
                echo (int)
$time_arr[1] . " min Shorter";
            echo (
'<br />Than Yesterday');
            </span>
      </div>
Regards, Jerry Wilkins
gwwilk@inebraska.com
Offline mcrossley
  • Wilmslow, Cheshire, UK
    • none
  • Win 7/Srvr 2008R2
    • WilmslowAstro Weather
« Reply #21 on: January 31, 2013, 07:55:18 PM »
Neat, I've gone for a dead simple implementation on my index page as the hours info is already there.
I have also added in 'dusk' as pink sectors either side of daylight, and I rotate the chart to keep the day sector centred on 9 O'Clock.
All done client side in JavaScript on my page though.
http://weather.wilmslowastro.com/index.htm
Edit: the relevant bit of script is below (should be easy to convert to PHP) , I have two values available, "daylength" = sunrise-sunset time (hh:mm), and "daylightlength" = start of morning dusk to end of evening dusk (hh:mm). If both those values are not available in WD, then the calculation to centre the day sector may be useful?
Code: [Select]
dayPct = (+cumulus.daylength.split(':')[0] + cumulus.daylength.split(':')[1] / 60) / 24 * 100;
duskPct = (+cumulus.daylightlength.split(':')[0] + cumulus.daylightlength.split(':')[1] / 60) / 24 * 100;
duskPct -= dayPct;
nightPct = 100 - dayPct - duskPct;
duskPct /= 2;
cumulus.daylightChart = '<img src="http://chart.apis.google.com/chart?' +
'chs=75x75' +
'&amp;chtt=day/night' +
'&amp;chts=000000,12' +
'&amp;chma=0,0,0,0' +
'&amp;chd=t:' + duskPct + ',' + dayPct + ',' + duskPct + ',' + nightPct +
'&amp;cht=p3' +
'&amp;chp=' + (Math.PI - (dayPct + duskPct * 2) / 100 * Math.PI) +
'&amp;chf=bg,s,FFFFFF00' +
'&amp;chco=F046A1,FFD700,F046A1,303060' +
'" alt="day/night ratio"/>';
« Last Edit: February 01, 2013, 09:41:20 AM by mcrossley »
Mark
Offline aggets
  • Sun Prairie, Wisconsin USA
  • Win 7/Srvr 2008R2
  • Firefox 18.0
    • Sun Prairie Weather
« Reply #22 on: February 01, 2013, 09:34:02 AM »
Thanks Jim
Got it running on my sidebar http://www.sunprairieweather.com/
Andy
Offline gwwilk
  • Lincoln, NE
  • Win 7/Srvr 2008R2
  • Chrome 24.0.1312.57
« Reply #23 on: February 04, 2013, 04:25:07 AM »
I should have warned you that my version of the script is set up for use in the menubar only.  The float:right style of the white text has put it at the far right of your page where white on white is obviously invisible.  Do you not plan to use it in the menubar?  Put it in your menubar as posted, and it should be just fine.
« Last Edit: February 04, 2013, 04:26:45 AM by gwwilk »
Offline Bunty
  • Stillwater, OK
  • Win 7/Srvr 2008R2
  • Firefox 19.0
    • Stillwater Weather
« Reply #24 on: February 04, 2013, 11:40:18 AM »
Okay, thanks,  I got both percentage numbers showing in the pie showing on the test page.  Didn't want to do move it beyond the test page until I figured out how to get the minutes more sunshine showing other than 0.
Offline jmcmurry
  • Jim McMurry
  • Mauston, WI, USA
  • Win XP
  • Firefox 18.0
« Reply #25 on: February 04, 2013, 12:06:06 PM »
I often see "0 min Longer", just give it a day or two and see what happens with that tag.
- Jim
Offline gwwilk
  • Lincoln, NE
  • Win 7/Srvr 2008R2
« Reply #26 on: February 04, 2013, 01:18:20 PM »
If you lived in higher latitudes you would see larger day-to-day differences :)  I show 2 min. longer daylight today.
Offline niko
  • syzygy
  • Global Moderator
  • Northern California, U.S.A.
  • Win 7/Srvr 2008R2
  • MS IE 9.0
« Reply #27 on: February 04, 2013, 05:08:27 PM »
I don't think that's the issue, tiggrweather is farther south than Stillwater OK and the tag is showing 1 minute, so I suspect there may be a problem with the Stillwater $changeinday tag. IIRC the WD change in day is driven by the solar max calculation, and not the rise/set times, so if solar isn't set up (I see Stillwater has zero for the solar readings) it may not work.
Offline gwwilk
  • Lincoln, NE
  • Win 7/Srvr 2008R2
« Reply #28 on: February 04, 2013, 06:29:28 PM »
OK.  Thanks, Niko. #-o
Offline Bunty
  • Stillwater, OK
  • Win NT 6.2
  • Firefox 18.0
« Reply #29 on: February 04, 2013, 08:11:53 PM »
While there's a lot to look over,  I've tried looking for likely looking settings for that in some of the saratoga files, but couldn't find anything.
