Hi Guys,
It’s been ages that I’ve been updating the SteelSeries Gauges that I’m using on my website, so the following could be related to that. Yesterday I installed my Davis VP2 ISS on the roof of my house and everything is working smoothly. Changed the settings in Weather Display and within a minute the data from my Davis was showing on my website :-).
Last night I noticed the 2.0.1 upgrade from the SteelSeries Gauges and wanted to update them on my website and started a testrun. I’m not sure why but in the 2.0.1 version I notice that the windspeed in kmh is 3.6 times higher than in the 1.6.5 version I’ve been using so far. It seems 2.01-script is thinking that I’m uploading my CustumClientRaw.txt (CCR-file) in Windunit = meters per second than kilometers per second. I’ve checked the CCR-file and noticed that windunit is set to “kmh”. Below you find the URLs to the 1.6.5 and 2.0.1 version of my gauges. Both are using the same CCR-file as data. What am I doing wrong here?
1.6.5: http://www.westlandsweer.nl/gauges/gaugeswestland.htm
2.0.1: http://www.westlandsweer.nl/gaugess/gauges-ss.html
My CCR-file:
{"date":"12:26","dateFormat":"d/m/y","temp":"11.6","tempTL":"10.4","tempTH":"11.6","intemp":"20.1","dew":"8.4","dewpointTL":"7.9","dewpointTH":"9.8","apptemp":"8.5","apptempTL":"5.9","apptempTH":"10.9","wchill":"9.6","wchillTL":"10.4","heatindex":"11.6","heatindexTH":"11.6","humidex":"12.1","wlatest":"14.5","wspeed":"16.9","wgust":"32.2","wgustTM":"43.5","bearing":"138","avgbearing":"169","press":"1008.6","pressTL":"1008.6 ","pressTH":"1017.3 ","pressL":"919.0","pressH":"1049.6","rfall":" 0.0","rrate":"0.0","rrateTM":"0.0","hum":"81","humTL":"81","humTH":"91","inhum":"45","SensorContactLost":"0","forecast":"increasing clouds and cooler. precipitation possible and windy within 6 hrs.","tempunit":"C","windunit":"kmh","pressunit":"hPa","rainunit":"mm","temptrend":"+0.8","TtempTL":"09:46","TtempTH":"12:24","TdewpointTL":"09:37","TdewpointTH":"01:01","TapptempTL":"08:04","TapptempTH":"22:33","TwchillTL":"12:24","TheatindexTH":"12:24","TrrateTM":"00:00","ThourlyrainTH":"","LastRainTipISO":"28/12/2012 23:54","hourlyrainTH":"0.0","ThumTL":"12:07","ThumTH":"00:00","TpressTL":"12:26","TpressTH":"00:00","presstrendval":"-3.7 ","Tbeaufort":"6","TwgustTM":"05:18","windTM":"27.6","bearingTM":"179","timeUTC":"2012,12,29,11,26,39","BearingRangeFrom10":"103","BearingRangeTo10":"231","UV":"0.0","SolarRad":"0","CurrentSolarMax":"163","SolarTM":"0","domwinddir":"Southerly","WindRoseData":[0.0,0.0,0.0,0.0,0.0,0.0,0.0,591.0,2184.0,367.0,0.0,0.0,0.0,0.0,0.0,0.0],"version":"10.37R","build":"45","ver":"8"}
