I’ve installed Henkka’s latest 3in1 version, and it’s functioning here. For some reason the temperature colors aren’t displayed, and I can’t see how to restore them. Does anyone have a solution?
Hi there,
Actually F-numbers colors are not set, but is easy to do as now colors are in a simply php-function when use CSS @font-face for the numbers. In addition, now there are then no limits how high/low it can go as it is actually just the font of the number whats changed to Highway Gothic
In wxall.plaintext.php, line around 630, function getcsscolor()
Just change the numbers in all the $raw==32 and so on
In current version are 0 first blue one and 1 first green one (= freezing point).
If anyone do the conversion, please post it here and i will add it to the script.
// Henkka
Thanks, Henkka! That works, sort of. The spread in F is fairly narrow, maxing out at 70
How about a UOM switch in the routine to convert $raw from F to C before colorizing it? I'll play with it some more.
Feel free to do it. Its a plain simple php so ex i[/i] works. That way you get 2 F for same color if needed for some colors. The difference between each color are farily small so even if say one color every 10 are defined for 2 F it will not be any that big visble “jumps”. There are ~76 colors defined. You can see wich degree C gives wich colore here on my testpage when i played with it if any help for putting up the F-scale (Note! In use are set 3. “No border”)
There are a setting for “useUS” i think (whats not applyed to this yet) and easy to be implented.
// Henkka
That worked like a charm, Henkka. Here is my sivu2.php page now.
This is the new code, colorized from -45
[quote]This is the new code, colorized from -45
