[quote author=Budgie link=topic=56317.msg451597#msg451597 date=1344115008]
Yep, Stationless should work fine and then add either Labjacks or 1-Wire as an extra sensor.
Having used 1-Wire, that’s all I have to go on, but all you need is the 1-Wire solar sensor and the USB adaptor to run it with WD.
Once WD is set up with your location, it will calculate the max solar for your location & time of day to give you the solar percentage. There is very little calibration required other than getting the sensor in a position where it can “see” 180
