Author Topic: Solar sensor: Solar Cell + LabJack + Weather Display  (Read 16278 times)
Offline Budgie
  • Martin
  • Global Moderator
  • CWOP: CW7959
  • Lochaber, Scotland
  • Win 7/Srvr 2008R2
  • Firefox 14.0.1
    • Lochaber-Weather
Re: Solar sensor: Solar Cell + LabJack + Weather Display
« Reply #30 on: August 25, 2012, 11:21:03 AM »
No overheating that I noticed, although the Northwest of Scotland isn't know for having a hot climate.  :lol:
The Hobby Boards sensor wasn't that far off the Davis TBH, although I didn't do any actual comparisons between the two.
Offline SkyHawk
  • Win Vista/Srvr 2008
  • Firefox 14.0.1
« Reply #31 on: August 25, 2012, 11:57:17 AM »
Ok.  :lol:
Thanks.  :wink:
Offline SkyHawk
  • Win 2000
  • Firefox 12.0
« Reply #32 on: September 02, 2012, 12:33:54 PM »
Hi again,
I was trying to set up the 1 wire solar sensor.
I am using Windows 2000 and I have the sensor connected with an USB adapter.
But when I was trying to install the Maxim's drivers, I have seen that they do not support USB with Windows 2000.
Is there any other drivers that can work? Is it possible to use a USB to Serial adapter?
Online Weather Display
  • Davis VP2
  • New Zealand
  • Win 7/Srvr 2008R2
  • Firefox 14.0.1
    • Weather Display
« Reply #33 on: September 02, 2012, 11:44:15 PM »
yes, a good quality usb to serial adaptor should work OK via the serial 1 wire connector
Offline SkyHawk
  • MS IE 9.0
« Reply #34 on: September 05, 2012, 02:49:20 PM »
Finally, I have managed to get a computer with Windows XP so, now I do not have any more problems with this.
I have followed Budgie's FAQ: http://www.weather-watch.com/smf/index.php/topic,55858.0.html
By the time, I have a similar window to this. So, I understand that the sensor works.
If I open Weather Display leaving the Dallas 1 Wire Reader running; in "Current Reading" in the "Solar Sensor Setup" page, I am getting the same data as in the Dallas 1 Wire Reader.
It confirms that the sensor works and is interacting with the computer.
My problem now is that the data is shown in mv, not in w/m2, and I do not Know how to change it.
Another thing is that I only can see the sensor graph in the "Extra Sensor Real Time Graph" page, but not in the main graph page.
Basically, I need a bit of help about how to configure the sensor in the Weather Display program.
Is there a guide about how to configure the sensor or the different steps I have to follow?
I have never done something like this and I do not want to skip any step.
Thanks for all your patience and all your help.
  • Davis VP2
  • New Zealand
  • Win 7/Srvr 2008R2
  • Firefox 14.0.1
    • Weather Display
« Reply #35 on: September 06, 2012, 12:47:11 AM »
there is a setup in control panel, solar setup...where you set to use 1 wire and you set the max mvolts
Offline SkyHawk
  • MS IE 9.0
« Reply #36 on: September 08, 2012, 07:06:31 PM »
More or less I have configured the sensor; but I can not find the place to set the max mvolts, so I could not make this adjust.
The solar sensor page is empty, as you can see in the pictures.  :?
Another thing is that, when the solar sensor's data is 9 mv or lower (in Dallas 1 Wire Reader or in Current Readings page in WD), in Weather Display the readings low to 0 w/m2.
For example:
     10,5 mv ---> Some w/m2
      9 mv     ---> 0 w/m2
More or less is near the 9 mv when it happens, but I can not confirm it exactly because now it is night here.
Is there any solution to any of these problems?  :oops:
Thanks again.
The solar setup is almost finished.  :wink:
Offline SkyHawk
  • MS IE 9.0
« Reply #37 on: September 09, 2012, 08:00:27 PM »
I have solved the problem of the 9 mv, but I still can not find the place to set the max mv.
As you can see in the pictures above, the pages of the 1 Wire sensor are empty, and there are not options to set the max mv.
What can I do to change it?  :?
Offline SkyHawk
  • MS IE 9.0
« Reply #38 on: September 10, 2012, 03:51:35 PM »
I have used the Forum Searcher but I have not found anything about this.
Please, can you tell me exactly where is the place to adjust the max mv? I can not find this in WD?
Thanks for your help.
« Last Edit: September 10, 2012, 10:25:14 PM by SkyHawk »
  • Davis VP2
  • New Zealand
  • Win 7/Srvr 2008R2
  • Firefox 14.0.1
    • Weather Display
« Reply #39 on: September 10, 2012, 10:45:20 PM »
make sure you have set to use 1 wire as well
in the com port setup, 1 wire
Offline SkyHawk
  • MS IE 9.0
« Reply #40 on: September 11, 2012, 03:42:58 PM »
Yes, that was the problem.  #-o
Thankyou.
Now, I understand that where it puts 200 I have to set the max mv. And the 0 is the place for decimals.
If it is correct, then I have to tick "Use this value" and "Calculate % from raw compared to max". But I have to leave not ticked "Plot this %" of the Labjack. Is this right?  :o
Thanks again.  :wink:
Offline SkyHawk
  • Win 7/Srvr 2008R2
  • MS IE 9.0
« Reply #41 on: September 22, 2012, 02:38:17 PM »
Finally I have the solar sensor working properly.  :)
After being calibrated, I have compared the readings with another weather station and the readings are quite the same.  :D
As I have said:
Quote
I am doing a Pre-University research project about Sun that will punctuate me for the access to the university; and one part of this project will be record data of the solar radiation in my city. But it do not have to be very accurate.
So, is there some way to save the data recorded with WD?
I have seen that in "Advanced Graph" you can save the graphs of the last hours.
But I wonder if there is some other way apart from this to do that.
In summary: What are the possible methods to save the data acquired by the sensor?  :?:
« Last Edit: September 22, 2012, 02:42:02 PM by SkyHawk »
  • Davis VP2
  • New Zealand
  • Win 7/Srvr 2008R2
  • Firefox 15.0.1
    • Weather Display
« Reply #42 on: September 24, 2012, 02:45:00 AM »
there is a logfile, vantagelog.txt
thats has the solar wm/2 in it
or you can create your own logfile, using custom tags (e.g for solar, time, date, etc)
Offline johnsonmaria
  • San Jose, CA
  • Win 7/Srvr 2008R2
  • Firefox 54.0
    • Analog Technologies, Inc.
« Reply #43 on: June 24, 2017, 12:24:15 PM »
I am also new here and I had same question. Now, after reading other people replies few of my doubts are cleared.
