Author Topic: Rain to date chart  (Read 6499 times)
Offline Fred
  • Davis VP2
  • Mercer Maine, USA
Rain to date chart
« on: October 07, 2002, 07:42:20 PM »
The rain to date (or 7 days rain) has a minor error.  holding the mouse over one of the monthly rain bars gives a value labeled as inches, but is clearly in mm.  For all except the current month, that is, which has the correct inch value.
No big deal, just thought you would like to know.
Fred
Fred LaPlante - WA1DLZ
Offline grhughes
  • Huntsville,Alabama, USA
    • RuppWorld
Fred
« Reply #1 on: October 07, 2002, 10:27:29 PM »
This has been broken for over a year.  It would be nice to get this fixed.
-Rupp
WinXP
Davis VP
  • Davis VP2
  • New Zealand
    • Weather Display
Rain to date chart
« Reply #2 on: October 08, 2002, 02:19:17 AM »
try vers 9.15b
should fix this
Offline Fred
  • Davis VP2
  • Mercer Maine, USA
Rain to date chart
« Reply #3 on: October 08, 2002, 11:34:51 AM »
Brian,
That did it.  But you might want to look at the bar for February.  Looks like that one got handled twice somehow.  The value here is about 1/2 of its neighbors, but length of the bar is way shorter (maybe 1/10).
Fred
  • Davis VP2
  • New Zealand
    • Weather Display
Rain to date chart
« Reply #4 on: October 09, 2002, 01:34:04 AM »
there was 1 line of code i forgot to fix
the vers there now should be OK
Offline Fred
  • Davis VP2
  • Mercer Maine, USA
Rain to date chart
« Reply #5 on: October 09, 2002, 01:40:00 AM »
Thank you sir.
Fred
Offline alf
  • Franklin North Carolina USA
    • http://www.trashwood.com
not working with groweather
« Reply #6 on: October 09, 2002, 03:35:13 PM »
It looks like the Oct monthly total is now correct using Groweather, but there is still a problem with the previous 9 months.  Previously, I have had to reset each month because of the roll over problem, but that seems to be fixed now in v15.e.  The new problem has to do with Jan through Sept.   It looks like the original monthly total is divided by 25.4. For example: Jan total should be 3.0 in and v15.e shows the total as .118 in. Hope this helps.
Andy
Andy Foppe
Davis Vantage Pro Plus Station (Wireless)
Windows XP Pro
Offline alf
Rain to date chart
« Reply #7 on: October 24, 2002, 04:41:19 PM »
Hi Brian
Just noticed that you have fixed the Rain to Date Chart so I am able to correct my Jan to Sept readings.   :D  :D   Thank you so much.   I also like that the readings fill the columns more.  Using a larger scale of column area to actual rainfall has certainly improved my monthly rain display. One question;  what is the maximum monthly value that the chart will register?  It looks like about 10 inches or 250mm.  Thanks again.
Andy Foppe
Andy Foppe
Windows XP Pro
  • Davis VP2
  • New Zealand
    • Weather Display
Rain to date chart
« Reply #8 on: October 24, 2002, 05:08:28 PM »
i do get there slowly
yes its 250mm
