For whatever reason I get a crash every now and then, no big deal. I usually check the version numbers of what WD I have the newest release, and if it has been a while I go for the update. The last few times after the update I found that I have to go through the set up wizard to get things back up and running. Things like the Com Port, Weather Station Model, Lon/Lat, and others in that Wizard all have to be reset again before everything seems to be normal again. Like after the update the data that was always stored some place and repopulated itself is not there anymore, and I have to start fresh again. Anyway I never had to do this step before. I know this time I clicked the save changes drop down under exit (?) and then restarted and all is good. I do not know if after the next crash it will repopulate itself.
Also, I noticed this time, after the crash, that it seemed like WD was trying to restart itself but got hung up – Along with the Regular WD screen, there was also a screen that was asking what language I wanted to use upon setup. English was ticked but I guess it couldn’t continue because it needed someone to click ok.
Thanks for any help or suggestion,
yamiacaveman
