Re: Not Uploading to CWOP Build-23 [RESOLVED->antivirus blocked it
I just recently updated from Build-16 to Build-23. After the update I could not upload to CWOP. I reinstalled Build-16 and the CWOP upload works fine. I did some searching in the WD folder. In Build-16 there are 3 “cron” files: “croncwop.exe”, “cronledsign.exe”, and “cronwdwu.exe”. In Build-23 there is only 1 “cron” file, "cronledsign.exe. The “croncwop.exe” and “cronwdwu.exe” are missing from Build-23.
Brian, can this be checked for the next Build? Thanks much in advance …
http://indiantrailweather.com
Cheers,
Jeff
how are you updating WD?
all those cron programs are included with the full install update
I’m updating from the full install updates. One curious note: the file “cronwdwu.exe” appears to be a virus which has come into my system 4 times this year which AVG has grabbed and quarantined.
Jeff
that will be the problem most likely, your antivirus program
its deleting or blocking those needed cron programs
Brian,
I’ve had 40 successful, consecutive uploads to CWOP using Build-16 since I deleted Build-23 and reinstalled Build-16. Per your suggestion I added “croncwop.exe” and “cronledsign.exe” to AVG’s allowed list.
Thanks for your review and comments …
Jeff
best thing to do is to .zip and email me your settings files
Which “settings files” to zip and email? Also, is the file “cronwdwu.exe” a Weather Display file?
There’s a FAQ on how to send your files to Brian…
http://discourse.weather-watch.com/t/12684
Mark,
Thanks for the link … The files have been sent.
Jeff
Brian,
Thank you for your review, input and suggestions.
You resolved the issue. I have reverted back to your latest version (b23) and all seems uploading to CWOP OK.
I went into AVG and in the Identity Protection settings under advanced I set to
