Author Topic: VpConsole: No response after several retries for Wake Up Console  (Read 6780 times)
Offline ewagnernl
  • Win 7/Srvr 2008R2
  • Firefox 10.0.2
I have installed the following configuration:
Davis Vantage Vue
USB Logger at Davis Envoy trough com5, using Silicon Labs CP210x USB to UART Bridge driver.
Weather Display 10.37Q b87
Weatherlink  5.9.3
I have configured the registerd Virtual VP Version 1.2.5:
Vantage Pro at COM5, VP Can restart the Davis USB logger.
Weather Display at Console TCP/IP 127.0.0.1 port 5511
Weatherlink at Consol TCP/IP 127.0.0.1 port 5512
I received every other second a error message:
08:25:56:347 Warning      - VpConsole: No response after several retries for Wake Up Console
08:25:58:308 Warning      - VpConsole: No response after several retries for Wake Up Console
08:26:03:208 Warning      - VpConsole: No response after several retries for Wake Up Console
08:26:08:565 Warning      - VpConsole: No response after several retries for Wake Up Console
08:26:16:669 Warning      - VpConsole: No response after several retries for Wake Up Console
08:26:18:737 Warning      - VpConsole: No response after several retries for Wake Up Console
08:26:26:566 Warning      - VpConsole: No response after several retries for Wake Up Console
08:26:31:948 Warning      - VpConsole: No response after several retries for Wake Up Console
08:26:34:020 Warning      - VpConsole: No response after several retries for Wake Up Console
08:26:40:152 Warning      - VpConsole: No response after several retries for Wake Up Console
08:26:46:683 Warning      - VpConsole: No response after several retries for Wake Up Console
08:26:52:790 Warning      - VpConsole: No response after several retries for Wake Up Console
08:26:54:846 Warning      - VpConsole: No response after several retries for Wake Up Console
08:26:56:916 Warning      - VpConsole: No response after several retries for Wake Up Console
08:27:02:985 Warning      - VpConsole: No response after several retries for Wake Up Console
08:27:07:127 Warning      - VpConsole: No response after several retries for Wake Up Console
08:27:13:206 Warning      - VpConsole: No response after several retries for Wake Up Console
08:27:15:265 Warning      - VpConsole: No response after several retries for Wake Up Console
08:27:17:342 Warning      - VpConsole: No response after several retries for Get Live Sensor Data
08:27:18:282 Warning      - VpConsole: Far too long since last loop = 5,007, last command= Get Live Sensor Data
08:27:20:600 Warning      - VpConsole: No response after several retries for Wake Up Console
08:27:22:676 Warning      - VpConsole: No response after several retries for Wake Up Console
08:27:32:961 Warning      - VpConsole: No response after several retries for Wake Up Console
08:27:41:241 Warning      - VpConsole: No response after several retries for Wake Up Console
I have tried nummerous different settings but the error message continues to appear and no clue anymore what to do. Both Weather Display and Weatherlink appear to work fine for a couple of hours.
Any ideas
Offline Budgie
  • Martin
  • Global Moderator
  • CWOP: CW7959
  • Lochaber, Scotland
  • Win 7/Srvr 2008R2
  • Firefox 10.0.2
    • Lochaber-Weather
Re: VpConsole: No response after several retries for Wake Up Console
« Reply #1 on: March 17, 2012, 10:43:31 AM »
Have you just started using VVP or has it worked in the past?
Do you get any data into WD & WL through VVP or does it always show the errors?
If you're using Window 7 then check the power save settings and make sure that the USB ports don't have the power save turned on as this can disable them even if they are being used.
Do you have the latest Silicon Labs drivers?
Offline ewagnernl
  • Win 7/Srvr 2008R2
  • Firefox 10.0.2
« Reply #2 on: March 17, 2012, 02:16:41 PM »
Hello,
All power settings are disabled, both in the version 6.5 driver setting as in the advance energy setting.
These errors always appear although both Weaterlink and Weatherdisplay are receiving data normally from Virtual VP.
Offline Stevec4
  • Boston MA
  • Win 7/Srvr 2008R2
  • MS IE 9.0
    • My Current Weather
« Reply #3 on: March 17, 2012, 07:15:57 PM »
I get these errors as well usually every night during the daily change over for WD. Do you have someting set to run at 8:25 that maybe interfering?
Offline ewagnernl
  • Mac OS X 10.7.3
  • Chrome 16.0.912.77
« Reply #4 on: March 18, 2012, 06:33:11 AM »
The 8:25 time is just a snapshot, the errors occur every 2 seconds 24/7
Offline Stevec4
  • Boston MA
  • Win 7/Srvr 2008R2
  • MS IE 9.0
« Reply #5 on: March 18, 2012, 11:00:18 AM »
Could you post a screen shot of your settings page in virtual vp. If your using comm 5 have you tried using the serial ports for weather link and wd versus trying to run them over tcp/ip
Steve
Offline ewagnernl
  • Win 7/Srvr 2008R2
  • Firefox 11.0
« Reply #6 on: March 18, 2012, 12:10:04 PM »
This is a screenshot of my virtual settings. It is the VP console reporting errors, this also happens when Weatherlink and/or WeatherDisplay are not connected.
Offline Stevec4
  • Boston MA
  • Win 7/Srvr 2008R2
  • MS IE 9.0
« Reply #7 on: March 18, 2012, 01:08:12 PM »
I was never able to get this to work properly using TCP/IP. I am posting a screenshot of my settings as a reference.
Since your using USB have you tried using the virtual comm ports?
Offline ewagnernl
  • Mac OS X 10.7.3
« Reply #8 on: March 18, 2012, 04:08:50 PM »
Thank you. I have never tried to install virtual comm ports. Guess that will be the next step to try. What virtual comm app should I use best?
Offline Stevec4
  • Boston MA
  • Win 7/Srvr 2008R2
  • MS IE 9.0
« Reply #9 on: March 18, 2012, 07:29:23 PM »
I am using the N8VBvCom Driver it has been very good for me over the years.
On the Virtual VP DOwnloads page there are a few links to other drivers.
Steve
Offline ewagnernl
  • Win 7/Srvr 2008R2
  • Firefox 11.0
« Reply #10 on: March 19, 2012, 05:16:03 AM »
Steve,
I have installed the N8VBvCOMS drivers and have it operational within Virtual VP. Unfortunately the error messages keep appearing, althoud Virtual VP seems to work correctly. Both Weather Display and Weatherlink are receiving data.
06:13:42:094 Warning      - VpConsole: No response after several retries for Wake Up Console
06:13:52:365 Warning      - VpConsole: No response after several retries for Wake Up Console
06:13:54:442 Warning      - VpConsole: No response after several retries for Wake Up Console
06:14:02:596 Warning      - VpConsole: No response after several retries for Wake Up Console
06:14:12:914 Warning      - VpConsole: No response after several retries for Wake Up Console
06:14:14:984 Warning      - VpConsole: No response after several retries for Wake Up Console
06:14:23:236 Warning      - VpConsole: No response after several retries for Wake Up Console
06:14:24:985 Warning      - VpConsole: No response after several retries for Wake Up Console
06:14:26:170 Warning      - VpConsole: No response after several retries for Wake Up Console
06:14:30:302 Warning      - VpConsole: No response after several retries for Wake Up Console
06:14:36:406 Warning      - VpConsole: No response after several retries for Wake Up Console
06:14:38:477 Warning      - VpConsole: No response after several retries for Wake Up Console
06:14:40:535 Warning      - VpConsole: No response after several retries for Wake Up Console
06:14:43:469 Warning      - VpConsole: No response after several retries for Wake Up Console
06:14:48:808 Warning      - VpConsole: No response after several retries for Wake Up Console
06:14:50:877 Warning      - VpConsole: No response after several retries for Wake Up Console
06:14:58:908 Warning      - VpConsole: No response after several retries for Wake Up Console
06:15:00:979 Warning      - VpConsole: No response after several retries for Wake Up Console
This is how I have configured Virtual VP:
Offline Stevec4
  • Boston MA
  • Win 7/Srvr 2008R2
  • MS IE 9.0
« Reply #11 on: March 19, 2012, 12:28:19 PM »
I wonder if your reception is low? At least everything seems to be working. I only get the warning maybe once a day.  If everything seems to be working you could always uncheck the warnings so they are not logged and see how it runs for a few days.
Steve
Offline Tornado Tim
  • I Love storms!
  • Matangi, Hamilton, Waikato, New Zealand
  • Mac OS X 10.6.8
  • Safari 5.1.4
    • Matangi Weather
« Reply #12 on: March 27, 2012, 07:55:39 AM »
A firmware update of the console may help also to sort the problem out.
http://matangiweather.org
http://NZAPStrike.net- NZ Aus Pacific Strike Network
