The rain rate gauge hasn’t been working correctly with WD, I have attached an updated customclientrawlocal.txt file to the first post, please replace teh version in 1.6.6 with this file until the next release when I’ll roll it in.
I have updated the SteelSeries library to version 0.11.3…
These changes speed up the library quite a bit so I thought it would be worth providing an updated Weather Gauge specific version (as I normally supply the weather gauges releases). This ‘should’ be a drop in replacement for the existing file on your server.
The main changes are:
Radial
- Fixed Odometer being reinitialised every time the background was redrawn
- Fixed background changes drawing LCD background when Odometer visisble
- Disabled pointer shadow blurring, it was causing performance issues in some browsers
- added check for ‘knob’ parameter in drawRadialForegroundImage()
Odometer
- Added setValueAnimated() method
RadialBargraph
- Fixed issue with LED halo still displaying when LED was off
General
- Added full caching to: trendIndicator, MaxMinIndicators, LCDbackground, LEDimage,
LinearForeground, LinearBackground, LinearFrame,
RadialForeground, RadialBackground, RadialFrame, and RadialPointers - Stopped some variable leakage to the global scope
- Some code styling changes and fixes for minor syntax niggles
EDIT: Script updated, see below…
Opps, the last version of the cutdown SteelSeries script was a little too cut down - I left out the Odometer component. This version adds it back in again, it only really affects you if you use the odometer display on a gauge.
Version 2.0.0 is now out of beta and available. Enjoy
Version 2.0.1 is now available, it fixes the syntax error in gauges.js that affected WD users, no other changes.
Version 2.0.2 is available
Fixes issues with wind speed when your native units are km/h, also adds a decimal to the kPa barometer scale numbers.
Version 2.0.3 is now available, there are quite a few changes in this release, please see the first post in this thread.
Version 2.0.4 is now available, please see the first post in this thread.
Version 2.1.0 is now available.
There are quite a few changes in this release, please see the version control list.
Major headlines…
[ul][li]Wind RoseGuage is now enabled by default[/li]
[li]A wind run odometer has been added to the wind rose[/li]
[li]A new ‘basic’ template html page has been added[/li]
[li]Support for VWS users added (thanks to Ken True of saratoga-weather.org)[/li][/ul]
I intend to leave this package alone for a while now - except for bug fixes, translation updates etc.
Version 2.1.1 is now available.
Mainly some minor bug fixes and translation updates in this one.
The one change to watch out for is the renaming of the combined Steelseries & Tween script file. My original name choice was causing much confusion so I have bitten the bullet and changed the file name - now I await all the “version 2.1.1 doesn’t work messages” :roll:
Version 2.2.0 is now available.
The headline changes are:
[ul][li]The gauge sizes are now picked up from the HTML/CSS, this makes it easy for custom layouts to be created using mixed gauge sizes.[/li]
[li]The wind rose has changed from using a radar plot to a rose plot. Note the version of RGraph.rose.js included has been customised by me, the author is going to make changes to support this natively in a future release of RGraph.[/li]
[li]Ken’s Saratoga templates are now supported, the zip contains his gauges-ss-basic-inc.php file - note this has been changed from the file posted by Ken and used with v2.1.1 of the gauges.[/li]
[li]Added support for WeatherCat[/li][/ul]
The image below shows the old and new style wind rose, I use 8 points with my Fine Offset but the code should work with 16 or any number!
Version 2.2.1 is now available.
This is a fix for the automatic rescaling of the gauges on mobile devices which broke in 2.2.0, and a typo fix for “Longitude” in gauges-ssT.htm (intended for use by Cumulus users)
Version 2.2.2 is available. The main fix is for WeatherCat users, so Weather Display users can probably ignore this release. There is a slight tweak to the gauges-ss.css to pretty the units table slightly, and the Nederlands translation has been updated that’s it.
I have also updated the FAQ with information on tweaking the wind rose appearance.
Version 2.2.3 is available. It is primarily a bug fix for WeatherCat users using Knots for the wind speed units, so not much of interest for WD users.
It does update the SteelSeries library to v0.14.0 though, which introduces the user LED, so it you want to ‘play’ with that you may want to take a look.
Version 2.3.0 is available, the key change is the addition of support for Meteobridge, but the only change relevant for WD users is the updated windrose.js script which removes the blurring that sometimes occurs on the wind rose plot in previous releases.
Version 2.3.1 is available. A number of fixes in this release so I suggest everyone takes a look at it. At a minimum please update your copy of the steelseries library script files, the previous versions cause a script crash in Firefox v21+ if you use the following gauge frame types:
- Black Metal
- Shiny Metal
- Chrome
Version 2.3.2 is posted, not really relevant for WD users as it is a bug fix from 2.3.1 for WeatherCat users. It does however contain an additional Portuguese translation courtesy of Cumulus user ‘Werk_AG’
Version 2.4.0 is available. A bug fix for VWS users, and a new look UV gauge for everyone.
The updated files are gauges.js and customeclientrawlocal.txt.
Version 2.4.1 is available, fixes a bug in the rain rate gauge autoscaling when using Inches and the value is between 0.5" and 1.0"
Version 2.4.2 is available, fixes a bug in the rain gauge autoscaling when using Inches and the value is between 0.5" and 1.0" - I stupidly missed this change out from 2.4.1
