Author Topic: Laser Sensor for Snow Depth Sensing  (Read 30248 times)
Offline mikeym
  • Thornhurst, Pa USA
  • Win 7/Srvr 2008R2
  • Firefox 18.0
    • MikeyMs Thornhurst,PA Weather
Re: Laser Sensor for Snow Depth Sensing
« Reply #15 on: December 20, 2012, 04:06:38 AM »
Here's the latest from Richard @ Porcupine Electronics. So it looks like it will cost about $13 more for the LR4 and Fluke 414D versus the previous LR3 / Fluke 411D setup. The difference being the cost of the Fluke 414D
Mikey,
The LR4 will be $149, the same price as the LR3.  It will be ready to ship on Jan 7.
Richard"
Cheers
 :D
MikeyM
http://mikeymsweather.com/
Another VERY Happy WD user
Shuttle XS36v4 8 GB RAM
Davis Vantage Pro 2 wireless w/ Davis solar sensor
Laser Snow Depth Sensor LR4/Fluke 414D working in WD thanks to Brian
Offline Bjørn
  • Ulsteinvik, Norway
  • Win NT 6.2
  • MS IE 10.0
    • Ulsteinvikweather
« Reply #16 on: December 20, 2012, 11:19:09 AM »
Hi.
where in WD can i find the setup for this?? cant find it.
Also reg the New type fluke 414D and LR4 is compatible With WD??
  • Davis VP2
  • New Zealand
  • Win 7/Srvr 2008R2
  • Firefox 17.0
    • Weather Display
« Reply #17 on: December 20, 2012, 08:08:42 PM »
see under setup, advanced/misc...lazer snow...
Offline aardvark
  • Des Moines, Iowa
  • Des Moines, Iowa, USA
  • Win 7/Srvr 2008R2
  • Firefox 17.0
« Reply #18 on: December 20, 2012, 09:32:55 PM »
thought of something...  you need a cone or a shield around the unit to prevent wet snow or ice accumulating around the laser or sensor.. same issue with WD wind cups, they tend to freeze with wet snow .  The drip shields are crap that come with it  but maybe this summer when I am retired I'll explore options for a drip shield that is much bigger...
Davis VP2 Plus; 24h  FARS; Extra Temp Humid sensor (2); Extra Temp Station (2); Soil Moisture/Temp Station;Weatherlink IP;USB; MAC Mojave; Webcam; https://www.wunderground.com/personal-weather-station/dashboard?ID=KIADESMI1&cm_ven=localwx_pwsdash
Offline mikeym
  • Win 7/Srvr 2008R2
  • Firefox 18.0
« Reply #19 on: December 20, 2012, 10:57:48 PM »
There is no problem with snow accumulating about the sensor as it's mounted several feet off the ground and pointed downward and the Fluke 411D/414D or 419D are mounted in a waterproof enclosure with only about a 1 inch opening for the laser and led pointer to pass thru. I'll see if I can get a picture shrunk down enough to post. If not I'll PM you one.
Ops Laser sensor is the one on the right.
Cheers
 :santa:      :reindeer:
MikeyM
Offline aardvark
  • Des Moines, Iowa
  • Win 7/Srvr 2008R2
  • Firefox 17.0
« Reply #20 on: December 20, 2012, 11:04:50 PM »
that is extra cool.   We got about 12 inches and I had to wade outside in the drift to brush off the snow from the snow stick..  your item would have been great to have.
Offline Bjørn
  • Win NT 6.2
  • MS IE 10.0
    • Ulsteinvikweather
« Reply #21 on: December 21, 2012, 08:11:37 AM »
Thanks Brian.
Cant find Lazer snow info/setup Brian, have WD vers 45 installed.
can you point me to the correct tab on my photo??
Offline mikeym
  • Win 7/Srvr 2008R2
  • Firefox 18.0
« Reply #22 on: December 21, 2012, 02:20:00 PM »
Bjorn
The laser settings are in the 1-wire reader "other settings" tab.
Hope that helps.
Cheers
 :santa:   :reindeer:
MikeyM
Offline Bjørn
  • Win NT 6.2
  • MS IE 10.0
    • Ulsteinvikweather
« Reply #23 on: December 21, 2012, 02:44:22 PM »
thanks alot MikeyM. :D
Found the dallas Reader in wd folder and open it from there. :-)
didnt find in setup.....
Offline dendrite
  • Northfield, NH
  • iOS 6.0.1
  • Safari 6.0
    • Eastern US Weather Forums
« Reply #24 on: December 22, 2012, 12:51:33 PM »
This is intriguing Mikey. Looks like you have the chance for a lot of snow over the coming weeks.
I was leaning toward a MaxBotix high resolution outdoor sensor with temp compensation http://www.maxbotix.com/Ultrasonic_Sensors/MB7389.htm but I'm curious about the laser now. Do you have any charts between the 2 sensors to see how they perform comparatively for the same event?
Offline eongibier
  • Vaisala 520 - Détecteur de hauteur de neige
  • Château-des-Prés (France Haut-Jura)
  • Win NT 6.2
  • MS IE 10.0
« Reply #25 on: December 23, 2012, 08:26:17 AM »
Bonjour dendrite,
De loin,  après plusieurs tests la meilleur sonde et la LR3 associée à Fluke. La précision est  largement  supérieure.
Cordialement.
http://www.localsat.net
http://www.localsat.net/enneigement
http://www.localsat.net/forum/index.php?
Offline charmed
  • Fredericton, New Brunswick
  • Win 7/Srvr 2008R2
  • Firefox 18.0
    • Fredericton Area Weather
« Reply #26 on: January 13, 2013, 10:04:28 PM »
I have the LR4 on the way, should be here monday.  Already have the 414D and active usb.  Is there a how-to here somewhere?  I've looked but haven't found anything yet.
rick
Offline mikeym
  • Win 7/Srvr 2008R2
  • Firefox 19.0
« Reply #27 on: January 14, 2013, 12:42:18 AM »
HI Rick
Good point on the how to do. In the Dallas 1-wire reader under the "other settings" tab you need to check "Enabled" under the title "Lazer Range Finder Snow Depth" after your initial reading shows up you need to set that value in the "Offset" setting. As you can see in the screenshot my offset is 153 cm. Also "check" the "Enabled to calculate current snow depth". All this has to be done with only the Dallas 1-wire reading running. Make sure the WD is closed when you do this. After you have done that go to the "Main setup" tab of the 1-wire reader and "click" the "Save/Reset" button.  Close the Dallas 1-wire reader and restart WD which will automatically start the Dallas 1-wire reader. Disregard the settings that are "grayed out" as they are for the ultrasonic sensor as I actually have both hooked up, but the laser is the only one that will provide input to WD  if you have the laser "enabled".
Hope this helps. Good luck it's a great project. Feel free to PM me is you need any additional info. We have seen some problems at very low temperatures as the 414D is only rated to a min temp of 32 deg F (o C), so I'm in the process of adding a automotive bulb (1157) with a small thermostat to keep it from getting to warm.
BTW the support from Porcupine Electronics has been OUTSTANDING.
Cheers
 :D
MikeyM
Offline Breezy
  • Indian Trail Weather
  • Hessville, NY, U.S.A.
    • baldwinj1
  • Win 7/Srvr 2008R2
  • Firefox 18.0
« Reply #28 on: January 14, 2013, 02:05:41 AM »
Hi Mike,
The Laser Fluke 411D/LR3 is doing a great job here. Very accurate ...
Cheers,   :D
Jeff
http://indiantrailweather.com
Hessville, NY - USA
Jeff
W7-64, Intel Z170A 16 GB RAM
Davis VP2 Plus & Soil Moisture/Temp Sensors, Laser Snow Sensor LR4/Fluke 414D, 4 Webcams
Offline eongibier
  • Win NT 6.2
  • MS IE 10.0
« Reply #29 on: January 14, 2013, 01:10:57 PM »
mikeym
"Hope this helps. Good luck it's a great project. Feel free to PM me is you need any additional info. We have seen some problems at very low temperatures as the 414D is only rated to a min temp of 32 deg F (o C), so I'm in the process of adding a automotive bulb (1157) with a small thermostat to keep it from getting to warm"
Hello,
For the history of temperature, I solved the problem in a camera housing with heater thermostat.
I noticed that from -8 ° C, a significant error solved thanks to the subwoofer.
greeting
serge
