3in1 meteogram temp button not working
I’ve installed the latest version of the 3in1 scripts, which now seem to be working well - fantastic scripts!
However, when the meteogram loads, you can select any button except Temp/Precip/Pressure and they work fine. As soon as you select the Temp/Precip/Pressure button the graph goes blank and no other buttons work from then on. Need to reload the page again to make things work again.
http://www.waikawa.org/wx3in1forecast.php
Haven’t made any modifications to the graphs.
Any suggestions welcome. :smiley:
Thanks, Maree
Never attempted to go back to a view again until you posted. The same thing happens on mine, if you try to view any selection you have already viewed it shows blank.
Not sure why but this seems to be something new. Never noticed until about two days ago.
I have the same problem :roll:
I have exactly the same problem. I have been talking to the author about it and he’s looking at it.
Can someone with this issue send me plaintext.txt and lastret.txt as i have not seen the issue here.
Henkka
You can find my file here
http://www.folignometeo.org/foligno/plaintext.txt
http://www.folignometeo.org/foligno/lastret.txt
Alex :wink:
I have noticed that the great majority of users in our country, have the same problem, including myself …
Your site is working properly. :lol:
Henkka,
Mine can be found here…
http://stillweather.com/lastret.txt and http://stillweather.com/plaintext.txt
Jack
Got it re-produced, thanks guys for the files, and actually the bug showed up with own files too on my testpage :lol:
Easy fixed after did some comparements with my live-site what works OK and test-page and one trial/error.
Zip are updated.
The fix, if you don’t want to redownload the zip:
In wxall.lastret.php at line 1298 are this:
Remove it :smiley:
Henkka
Unfortunately this did not fix mine. You can view here and see http://stillweather.com/wx3in1.php
Jack
Work for me!!! thanks Henkka!
Thanks Henkka that worked for me.
Fixed here! :smiley:
The page seems to be loading faster also.
Thank You!
Thanks Henkka. :thumbright:
Found my issue, for some reason I had the same bit of code in my “top.php”. It works now, thanks Henkka!
Thanks Henkka for looking into this. I also confirm that this fixes the issue and the page seems to load faster. Appreciate your efforts and great work! :smiley:
Works me too.
Thanks Henkka!
