that error is because it should be using the https instead of http
but WD now uses the separate cronmetardownload.exe
what version of WD are you using?
also note that what you have posted is not the NOAA forecast 5 day download function though
10.37S-36 and this is the screen I am using to download the file. Don’t see an option to change HTTPS I am using the NOAA forecast download page test button
Did a fresh reboot and it appears working not sure why haven’t changed anything but I’ll take it!! Will watch for a bit see what happens.
Did you change the forecast item in customclientrawlocal.txt?
Yes working now looks good Thank You!!
OT: I was looking at your site, you need to get Google Maps API key, your maps arent working
Eg:
http://www.celinmeteo.com/wdisplay/weather_W.php
And in Czech, it should not be:
actualitzaci
Hi Jachym,
I used several weather stations: LaCrosse WS 2310, WMR968 Oregon, Oregon WMR200, Davis Vantage Pro2, Netatmo. Now I use only the last two.
Data archive can be found at WU.
Marian
:roll:
Just installing the Steelseries gauges and got the gauges-ss-basic.htm file to show all the gauges correctly but having trouble with the wxssgauges.php. Nothing displays in the wxssgauges.php but the attached. Any other settings I may be missing? Thanks
“only two” A true enthusiast
Disregard. I’m in the process of updating my templates and have created a dir on my web server for testing purposes. As such I forgot to modify the relative path for the SSG files in the wxssgauges.php.
Bill
Well everything has been working great until today the scroll on the gauges is stuck???
http://www.n7drd.org/wxssgauges.php
what did you have it set to show?
(the more information you can provide, the better)
%5dayforecastday1% been working great for a few months then today it sopped.
see other threads about that
(you need to be using build 42, as noaa changed the format)
Will update now see what happens. Thank You!
Thanks Again Brian worked like a charm!
I updated the Steel Series Gauges on my site today…they seem to be working OK https://www.turnerdownsweather.com/gauges-ss-basic.htm
I cannot remember how to incorporate the page into my Saratoga-Templates. Could someone please provide me with the code to make that happen. Thanks in advance…
Ronnie
I was able to get this resolved…please disregard.
Ronnie
I thought some here might be interested that I have created a way to have a site’s WXSim forecast in the scrolling ticker on their Steel Series Gauges page. Ideally I’d like to try it out with one or two people before making the necessary script generally available. So if you want to give it a go PM me and give me an email address I can send the php script to. You will also need the plaintext-parser scripts package from by Ken True at saratoga-weather.org (if you do not already use it).
You can see it working at https://www.stella-maris.org.uk/wxgauges.phtml but note I have no working UV sensor, rain gauge or wind speed at present so there is no data in those associated gauges.
Hi All,
Just got the Steelseries gauges up and running on my site. I am working on a customized dashboard that will display the gauges on an iPad, but I wanted to have the dew point and apparent temperature each shown on 2 separate gauges, instead of them being combined and toggled with a radio button.
I have mucked around in the code, tried a few different things, and searched through this forum, but I can’t seem to figure it out.
Any ideas?
Thanks!
