I found that it was the “downloading” message that interrupted the longer forecasts. At about line 985 I made the following changes and it works better for me. The second change was because I found it disconcerting that each countdown would begin with 10 regardless of what was set in the config.
getRealtime = function () {
// setStatus(strings.StatusMsg); // removed so "downloading" doesn't interfere with long scrolling forecasts
// _count = 11; // 10 seconds timeout
_count = config.counter + 1; // changed so that new countdowns start at the proper number rather than always 10
countDown();
$.ajax({url: config.realTimeURL,
dataType: 'text',
cache: false,
success: checkRtResp,
error: checkRtError,
timeout: 10000
I think you have misunderstood why the counter goes to 10, then jumps to your configured timeout.
When the script kicks off an Ajax download it sets a 10 second timeout for the download to complete, after that it retries. So if the web server was unresponsive for some reason, and you had a 30 second refresh, you would see…
Thanks Mark, I see I was way out in left field on that one, I’ll change it back. I just thought it a little strange that the 10 would always flash up there but now understand why.
OK so after all of that, I again ask how to increase the amount of time (and what file needs updated) so the Forecast scrolls longer before it resets and restarts.
It gets as long as the time you specify for the data refresh. So if you set the refresh time to 20 seconds, it gets 20 seconds to scroll before fresh data is down loaded.
thanks I did finally figure that out and have it working!! the server runs here at home and at the moment I have 2 running so it is slowing things a bit…that will change Friday when I move one out to a remote location!
Today’s Gauges stopped working, when entering the page the scroll shows Downloading … and the timer is at 60 without advancing without charge the information.
I am seeing a 404 not found error on your weatherstyle.css file which according to the URL used should be in the gauges directory. Make sure this is there in the correct place and see what happens.
Thank’s Mark : I will copy back the file in the WD, yesterday I was doing some changes to the website with Saratoga Template, and may have some local change in WD
OK update and fix custom customclientrawlocal in WD (PC), and change error : HTTP Request Failed 404 in the scroll Bar. File customclientraw.txt is update good, and script included on config directory path for file.
Your customclientraw.txt file exists in your root directory and not your gauges directory, you either need to correct where it is uploaded to or change the settings so the Gauges can find it.
Thanks, it was my mistake to delete some files that I thought were redundant. I made a new installation and adjustment cartepa all parameters again. Now is working again.
The forecast for the WD scroll works with some special file?
