Mark,
Sure thing, just did and opened both files with UltraEdit and they look just fine here.
- Jim
Mark,
Weird, I wonder if there is a corrupt copy cached somewhere?
Mark,
Jim kindly sent me a copy of his and it worked fine.
Mark,
Keep forgetting to ask this. Inside /scripts/ is another /scripts/. The first has all the needed goodies, and the second contains only another copy of steelseries.js. Is it really needed?
Downloaded and upzipped just fine for me, too. No problems whatsoever.
-Keith
Nope, that was included by error. I’ll clean everything up for the next release.
Tank U!
Just downloaded the 0.11.4-weather.zip update & I’m being told there are no files to extract so I am unable to insall it…
Any ideas?
Simon, try downloading the full zip file from the start of the thread, I have put the updated script in the full version: gauges-ss_v1-6-6b.zip
For some reason the forum servers do not like that update zip file.
Thanks Mark. Is that the only file that’s changed since the original 1.6.6? What’s the actual file I need there?
Cheers,
just the “steelseries.min.js”, I’ve actually made a few more updates since then but I’ll save them up for a while - busy working away on version 2 of the weather gauges and updating the SteelSeries library as I find minor issues.
Hi all,
after much research, I found this new version of the gauges, I downloaded the package followed the directions on the website to display weather, only problem, and 'that weather does not display the file conversion customclientrawlocal.txt —> customclientraw.txt, despite the file customclientrawlocal.txt and 'put in the same directory as the file Clientraw …
Can you help me?!?
For now I only see the gauges but are not entered the data …
Thanks in advance …
mark
have you set to create a customclientraw in the webfiles/web page setup /real time ftp setup in WD?
also make sure to not have your windows folder options set to hide known file extensions
We have followed the readme and ‘weather display so I set as shown in the attached image, and’ correct?!?
I do not understand why 'does not convert the file … customclientrawlocal.txt
here is the test page with the gauges still … http://www.ombarcellonapg.tk/wdisplay/Tachimetri/gauges-ssT.htm
It seems to have started to work as time to update and upload I put:
Update: 5sec Uploads: 10 sec and 'right?!?
As regards the rest of the graphics, can be able to put the pressure gauges such as those of weatherc?? Could someone kindly help me do that?
http://www.nordicweather.net/index.php?en
Thanks in advance.
ah,so having 60 seconds did not work…
how many seconds I have to put in your brian?
To customize the inside of the speedometer as to Henkka as I do!?
I have some troubles to run those scripts.
My customclientraw.txt file is uploaded into /html/wdlive so I put on line 21
g_realTimeURL = "../../html/wdlive/customclientraw.txt";
indeed, the gauges scripts are in /test/v3.
When I go on http://www.meteomelin.be/test/v3/gauges-ssT-fr.html everything is working but the autoupdate failed everytime. After that, it is impossible for me to go on www.meteomelin.be I have to reboot my server.
Any idea of what there is?
Sorry for my English
Sorry, I get a ‘page not found - 404’ error on your link.
This is the correct link.It’s .htm instead of .html
