In /wxgraphs/graphsconfig.php you’ll find this line: $margincolour = “(somecolor)”; (mine is set to “lightgray”).
Change it to the color of your choice, and that should do it. I think I finally noticed the graphs’ raised appearance on my site after I validated via CS3 and had to create a bunch of ‘gauges_’ specific copies of my Settings.php, top.php, header.php, footer.php, menubar.php, and common.php which I then modified in order to finally validate for HTML5 compatibility. The gauges use the UTF-8 charset. I just checked the compliance of my page, and there’s only the warning that the checker for HTML5 is experimental, so I guess I haven’t messed it up lately. Your graphs have the shadows now.
I also noticed this post in the Jgraph setup section…which helped also, as your comment did.
"are you running 3.5?
if so:
remove “required_once(‘jpgraph_theme.inc.php’) from the jpgraph.php script.
Then you will get the drop shadows.”
Not sure if you already had done this. After I did the above all was good.
BRGDS,
patrick
Recently fiddled with somthing in WD. Now my steel gauges aren’t updating. Hadn’t touched the gauges though. What might it be? iszatso.net/weather/wxsteelgauges.php
TIA,
BRGDS,
patrick
don’t upload the custom file from two places…
and never delete the customclientrawlocal file from the webfiles directory. These self responses may help another neophyte out when they wrap things around the axle.
p.
Hey Mark,
Thanks for the update today. Works fine.
Is there any way to get the wind speed to display the tenths? Right now it’s just the even mph (2.0, 3.0, etc.).
note that your weather station is not accurate to more than 1 mph for windspeed though
It displays what it it is given, mine displays in tenths, so as Brian has stated your station must only be supplying whole numbers. You can change the gauge config so that the LCD only displays whole numbers if that looks cleaner…
lcdDecimals: 0,
Understood, but it just ‘looks’ better.
My main site page displays mph in tenths (Davis VP2+ with Scott’s alt dashboard), so it’s getting it from somewhere. Will have to dig into that code and see where it’s coming from.
Have a look in your ccr file, is it in tenths there, if not then the tag may be the problem.
Don’t forget that the initial page load wind data loaded from the clientraw.txt will have been converted from knots, so it’s likely to have decimals in mph, and any calculated average will also result in decimals.
“wspeed”:“%avgspd%” passes a decimal - “wspeed”:“5.6”. The other wind items are all “x.0”. I assume function doWind() needs a little massage, but that is beyond my knowledge (much is these days).
Thoughts appreciated.
Understood.
Thanks, niko.
the averaging produces the decimal place
(it could be argued if that should be like that or not)
there are tags with no decimal from memory
wspeed = 10 minute average windspeed = green sector on gauge
wlatest = latest wind speed reading = gauge needle & digital readout
So as Brian says the 10 minute average is calculated to one decimal place which makes sense to me, but the readings from your station are in 1 mph increments.
Mark,
0.11.4 will not unpack for me. Downloaded twice, but it just locks up my unzipper.
Thank you! That was exactly the definition this old mind needed.
Now to dig into the tags list.
John, for some reason the forum does not like my zip files, I have created it using two different software (WinZip & Windows Explorer), and whilst both files look the correct size, they have zero files listed in the contents when you download them again. I have uploaded the same file to the Cumulus forum and it works fine. So I am at a bit of a loss now. ](*,)
But it downloaded fine for me and runs great. :dontknow:
- Jim
