To get all the dials to work you need to go into control panel, web page setup, custom web page and unstick the box “include units” atbthe moment the units will be uploaded to customclientraw which confuses things. Be aware that this will remove the units from any tags uploaded to any custom web pages you have created.
The scale of the gauge has to scale automatically, did the rainrate go higher as 10mm/h?
As it it is lower as 10, it scales to 10, at 11 it scales to 20, at 21 it scales to 30 etc. (for mm) for inches 1.0/2.0/3.0 etc.
Would seem mine did not scale…according to Wd it hit 65mm/h at one time today. I was looking at the Davis console and it was well over 10 mm/h. Yet the Steel Series remained pinned at 10 mm/h (no scaling).
I was thinking it should or would scale up…but it never happened.
%bftmaxgustlast24hrnu% is listed as a valid tag, but does NOT get processed by WD? (at least not by tame volunteers install using 10.37R b14)
Current temperature trend in words - there is no existing tag in WD. No big problem I can code around that one as I have the numeric value.
Direction of today’s max gust in degrees - there is no existing tag in WD. No problem I will use the ordinal direction %maxgstdirectionletter% as this value is only used in pop-up text.
Brian did already offer to create the %maxgustdirdeg%, the %bftmaxgustlast24hrnu% is in the tagslist but is indeed not working. And last but not least as far i know there is no tag for the temperature trend in text.
So maybe if we ask Brain nicely
create a %maxgustdirdeg%
check why the %bftmaxgustlast24hrnu% is not working 3. create if possible a temptrendtext
The first two fine, the last I do not need as the text would always be in the station language. The template is multi-lingual so I really should provide the text in the script according to the current language selection. I will make the same change in the next release for the Cumulus version as well.
EDIT: The value for Humidex only appears to be available in
Thanks, I have v1.6.0 almost ready for release. This will be much more WD friendly, you will be able to leave the units switched on for ccr processing if you want. It will have an optional Solar Rad gauge (as well as the UV). It will include a ccr template in the zip. It is all coded and seems to be working well.
What I am less sure of is how to layout 10 (or 9, or 8 ) gauges.
X = optional gauge
OOOO
OOOO
XX
or
OOO
OOO
OOXX
or maybe
OOO
OOOO
OXX
or even
OOO
OOO
OO
XX and let you place/remove the gauges manually in the HTML.
For those of us using the narrow window setting in WD, 4 across won’t fit, and even 3 across would probably hang off the edge a bit. I had planned on pre-setting my page to wide to fit 3 across. So, I would prefer…
OOO
OOO
OO
(O)(O)
…with the bottom two rows centered. Possible? Or, is there a single setting now to change the 251px to something smaller? I seem to remember seeing more than one place, but I could easily be wrong.
