Thanks weatherbee, maybe I'm missing something but I can't see that setting in there. Can you help?Line 16 for me in guages.js
var g_count = 5; //download data counter (secs, default 60)
Thanks Doug,
Can’t think how I missed that!
Simon
Would there be too much editing to make the gauges work with the existing clientraw.txt
I’m currently uploading?
I’ve been working on a page that combines the ajax page and the dials. Not perfected yet but what do you think?
http://www.shermanctweather.com/indextest.php
Impossible, most of them are tags who are not in the clientraw.
BTW guys these gauges are html5 only, so make a redirect for older browsers (IE8) to your old page.
Jacco
Ah ok. So I’m confused then.
{"ver":"5","date":"<#date format=hh:nn>","temp":"<#temp>","tempTL":"<#tempTL>".......
This is the realtimegaugesT.txt file that came with the download. Which do I change in this file and then save as a
2nd file to upload in realtime?
Sorry, I just need a push in the right direction. :oops:
Go back on to Jacco’s website and download the file called “customclientrawlocal.txt” at the bottom of his download page.
Tony,
Go here http://www.hetweerinruinen.nl/steelseries-gaugs-for-wd and download the customclientrawlocal.txt. Put in in your web folders and then go to the realtime setup page and set it up to update there.
wetherbee…you are reading my mind/1 http://stillweather.com/index2.php
Jacco…thanks for the tip about html5 that’s a nice solution!
Jack
Jack nice job. Yours is much better balanced than mine.
How did you get the graphs to work?
Thanks, and they really are not yet, look at the data, it’s wrong. Working on that though! Jacco posted something about it earlier, going to look at that now.
Jack
Jack,
Those pages you’ve created are beautiful! When you’ve figured out how to implement the graphs properly, would you be kind enough to write a tutorial here, for web novices like me?
Thanks Guys. I’m getting there. http://cnyweather.com/gauges-ssT.htm
Barometer is updating in inches but the gauge shows in hPa
In the clientrawlocal.txt change hPa to in, the units are hardcoded
Jacco
Starting to get the graphs working with jpgraphs and as Jacco stated using wxgraphs. A good tutoral for wxgraphs can be found here http://discourse.weather-watch.com/t/28585.
Jack
My gauges are a heavenly modded version of theese same steel gauges
Biggest issue with theese are, what have been pointed here too, that they will not work in IE’s below 9 (FF/Chrome are OK).
There are no way around that (tryed to found while i did my own ones without luck).
Yes, html5 are cool, but, so long a pretty big precent of the visitors use old IE’s (50% of all IE-users on my site use IE < 9), thanks to that XP-users are stuck on IE8, will it be a “problem”, have system what works also in IE8 or create 2 different pages shown depending on browser. Sigh…
After much playing i went to a version where i used my old gauges as base wich works also in older IE’s and copyed only needles etc codes from theese new gauges. No rocketsience inside, just plain canvas-code so its easy to copy once figure out how it works. As backgrounds i used screenshots of the generated gauges without needles/numbers. As result i got new gauges what works also in older IE’s
Depends on what you find an big issue Henkka.
If you have for example an ipad, and you go to youtube, you are also directed to a page optimized for ipad.
At the moment is is impossible to be compatible with all users, so then you have to make a choice.
Keep your website “old-fashioned” to satisfy all your users, or make a website with the latest technology,
and create a fallback for the ie8 xp users. Well then for me it is a very easy choice.
There will be xp users for ever, xp is almost 11 years old and end of life. Remember those days where in the
footer of a website it said: This page is optimized for Internet Explorer 7!
W7 is so much better than XP in my humble opinion anyway
(and it works just fine on an older pc that was running XP (just done that here OK))
Jacco,
Have you experienced any issues with the download of customclientraw stopping? I seem to have the issue even with bumping the default times up in gauges.js. I notice it on both the default gauges page and my website. There appears to be no issues with customclientraw being uploaded and or stopping however a qustion for Brian; What is the optimal setting for the second realtime FTP times so that there are no conflicts yet it load quickly?
Jack
you should not need to be needint to use the 2nd real time though?
Depends on what you find an big issue Henkka.Yes, but i look at the things in little bigger view than just myself (I use W7), I see in "vistors of the site"-view. Actually about 45% are IE-users of wich 50% use older versions than IE9. Thats quite a part of all visitors. And this in a country where IE<9 user-rate are low, in middle of Europe are the rate far bigger.
Its also a managing thing, if you want to do doublettes of everything instead of creating a page what works also in IE8 (i don’t care about IE<8 ), and then do double work, its your choise. I have many times allready said IE should be forbidden by law, its a pain in **** for coders with my own scripts, but have tryed to have them as IE8-compatible as possbile alltought as so many of visitors still use it.
Personally i should use much more HTML5 and all its cool stuffs if just more browsers should support it.
Keep your website "old-fashioned" to satisfy all your usersCan you call my site old-fashioned?? I should say no, and it still (almost) IE8-compatible. :) Its more a question how you as coder tackle the IE8-probleme than nothing else. At the end, those gauges are fully possible to get working also with IE8 and lower if wanted, its just question to be creative and learn the basics of . And before you ask, Google is your friend in that case, so i learned it too :D
