Dan,
The graphs, thats the next step, but i need something that creates great graphs to show in there.
So to be continued…
Jacco
Dan,
So to be continued…
Jacco
[quote author=Budgie link=topic=54749.msg439460#msg439460 date=1328546139]
How did you get the customclientraw.txt file to be produced without any units?
Most of them on my own file have
That may be the problem, just unticked it and will see what happens.
I’ll also need to make sure it doesn’t effect other files I upload.
That did the trick.
Now the gauges are working it’s time to get them onto a proper page and start having a play.
HI
I like them very much
and was hoping someone would make them available for WD
I could add option to WD to create with a tick the needed file with the needed data?
but using the custom client raw is not difficult,either , to setup, your instructions are great
and using the custom client raw means you have control more,…eg to add more etc
this needs to be made a sticky
ps , is it fact or just opinion that iphone/ipad sales are and are going to outstrip Andriod equivalent?
as I have android phone/pad and love them
Jacco,
Further to our conversations in the Cumulus forum I would like to thank you very much for posting here. As I thought, there is a lot of interest from WD users, myself included.
Simon
Having a little trouble with the conversions to US units. Most gauges converted with the changes made in gauges.js however the barometer gauge won’t change. Also the wind gauge reads “kph” even though it was switched to mph. Any suggestions?
Test Page… http://stillweather.com/gauges-ssT.htm
Check the unit tags in the clientrawlocal.txt. They are hardcoded. And the script reads the units from there.
the part: “tempunit”:“C”,“windunit”:“kph”,“pressunit”:“hPa”,“rainunit”:“mm”
Jacco
Check the unit tags in the clientrawlocal.txt. They are hardcoded. And the script reads the units from there.the part: “tempunit”:“C”,“windunit”:“kph”,“pressunit”:“hPa”,“rainunit”:“mm”
Perfect, thanks that did the trick!
Just wanted to thank you again for you help Jacco - this is amazing!
Here is my gauges page thus far: -
http://www.spireweather.co.uk/SteelSeries/gauges.htm
The only thing that doesn’t work is inside humidity…
Simon
Indoor humidity uses the %hum% tag in the download, it should be using %indoorhum%.
Also, if you have a VP2 then you can use %vpforecasttext% for the forecast, the download has just “Settled Fine” as a standard.
Brian,
Hi. Since the iPhone4s has come out, iPhone and Android sales have been pretty close, with Android taking the lead during the middle of the 2011. In the last few months of 2011, Android sales have dropped while iPhone 4S sales have risen as a percent of total sales: http://gigaom.com/2012/01/09/iphone-breathing-down-the-neck-of-android-in-u-s/ . That said, what is more important to weather website owners (IMO) is the web traffic, especially tablet traffic: http://www.padgadget.com/2012/02/01/android-tablet-web-traffic-still-no-match-for-ipad/ .
Another factor to consider is that Apple will be rolling out the iPad 3 and iPhone 5 in roughly March and mid year, respectively. That will bring in another influx of new users and more browsing by current users.
But it’s not important which platform we use personally. I like my iPhone (and iPad); it’s WAY better than my Win Mobile 5/6 (which was junk). You and several of my friends like Androids. No worries. They are all good devices.
The key is choice. I don’t want to be forced to choose my mobile devices based on what websites they can use. IMO, our websites should be fully available on ANY platform. Until now, the tablet which accounts for almost 55% of web traffic (iPad) could not see realtime weather. These SteelSeries Gauges and their offspring should change that. I want my website to be one of the first.
Dan.
they look great!
and they integrate very well into the web page
well done
Very nice! Especially the integration. This is the nicest integration of SteeleSeries graphs that I’ve seen. :thumbright: :thumbright:
Dan.
My first try with it, a few gauges aren’t working.
Nice work!
How have you managed to get the graphs to work on tapping the gauges?
There is no prob getting the graphs working, depends on what you want to show.
Here on my testpage the 1st gauge graph is working:
http://www.hetweerinruinen.nl/flash/gauge3/gauges-ssT-nl.htm
i used wxgraphs(jpgraph) to create the graph, in gauges.js set the var imgPathURL to your wxgraphs dir.
And in stead of ddimgtooltip.min.js use ddimgtooltip.js. Don’t forget to set this in your page also!
Edit ddimgtooltip.js, on line 24 etc you can change the temp.png in for example temp_24hr.php.
And then you have your graph made live on the fly.
Jacco
A couple more questions…
My gauges only seem to update once a minute but I understand the clientraw data is uploaded every 3 seconds. How do I get a truly “live” experience?
Also, this will be child’s play to many of you in here so please bear with me… What html code would I use to insert one live wind gauge into the sidebar of my website? So that clicking this takes me to my main gauges page?
Thanks in advance,
