Ok, good. If you hover your mouse over the login button do you see the address for that page? That is the address you will need to use in WD, and you will need to add your login details on the WD IP cam setup page as well. Let us know how you make out…
Here is a different view , with the arrow hover over log in . not clicking log in .
bottom left corner .
I would try the address to the URL you circled on the 2nd post. Put that whole address in the WD setup page along with your username and password and see if WD can connect.
Have you been clicking on “Start Preview” when you’ve changed the IP address?
Yea i have . That’s where I get error ; failed to start preview . bottom left side box
maybe try not having the
http://
Ok . tried that too . Still show Failer to start preview .
I also checked and un checked th ip box on top
Can you see an image from the webcam when you use the software that cam with the webcam?
Greetings!
Try to copy and paste the i.p. address in your browser, see if you can access the camera through your browser.
I have a similar setup as you, with my webcam, but, there are a few more parm’s needed to access it.
In your screen grab the URL is not correct. The URL shown in the earlier post was
http://192.168.1.253:8080/CgiUserLogin?Language=0
Try that and let us know what happens…
Yea , there is a picture in my web cam address. Is this what you was asking ?
I even put the address showen here in the web capture program . its not getting it .
Let me ask this . Could my web cam from Panasonic be stopping it ?
Which Panasonic webcam, I though you were trying to get your Panasonic BL-C140 working?
Do you have a second Panasonic webcam connected as well?
he might be refering to the software that came with the station?
On the last screen shot showing the image, if you right click on the image does it give you any options? If you can find a link direct to the image that may work for your WD setup…
Or…
Can you view the html of that page? See if there is a link in the html to the image being shown…
no change . Shows error failed to start
the thread title suggests you had this working at one stage?
hello rick/info…
think you need this…
http://camera.address/SnapshotJPEG?Resolution=320x240&Quality=Standard
…chris
