The new cell-ajax-dashboard.php fixed the problem with the UV forecast not showing at night. Thank you much!
John
John
John -
Glad that fixed the problem… You dont need the cell.php?skip=1 anymore… you can change your xml file…
I think you are using the older cell-radar.php and cell-advisories.php files… Take a look and swap out the width=“315” to width=“<?php echo($pagewidth-5) ?>” on all the image links. That dynamically changes the width to just be a bit smaller than the page width…
Updated “a” zip to include the fixed cell-ajax-dashboard.php.
Starting to see a few people use these – glad they are helpful to others!
Updated all pages with the width. Not sure which file you are talking about with the skip=1 as I haven’t found any that contain it anymore.
John
John – Your homepage
http://www.harpersferry-weather.com/cell.php?skip=1 … which is from menubar.xml
Thanks again. It was in my flyout-menu.xml .
John
yes sorry my bad… flyout-menu.xml. I knew it was some xml file lol…
OK fixed some issues that prevented the page from not displaying correctly on iphones… Had to a add a line to cell-top… Also fixed some formatting issues to make other pages look cleaner – thanks tstorm for all the help debugging this on iphones!!
main “a” zip updated with new files…
Sorry for all fast changes, but its getting pretty stable now I hope…
Looks good atsio! Your webcam tags still have the “alt” ref to my website but its not a huge deal…
Fixed!
Thanos
I downloaded your updated scripts again but cannot figure out how to change to FWI :?
Thanks for the hard work on this mobile script.
for FWI just set $fire = false; in cell-ajax-dashboard.php.
Also make sure your graphics are CBI-FireXX.gif. You can use whatever graphics you want, but for now the need to be named CBI-FireXX.gif where XX is 0,16,25,31,32.
I cannot find that setting, I am sure I have your latest cell-ajax-dashboard.php which i downloaded from this thread.
line 68
$fire = true; //True = chandler, False = fire weather
No not there, I must somehow have the older version of the script.
Yeah you do… I can tell … you have an older version…
I have downloaded again and now have correct version, don’t know what i did. My bad
thanks for help.
make sure you pickup the background
or use any background… just save the file too your root.
Tony -added a link to the UV/Solar images (first post) and the moon icons… There are 2 other files moon2.png and sun2.png which are in the zip you need to put in your ajax-images.
And HOLY UV there. wow… thats high!
I’m not sure how the forecast will work in NZ, but i can try to adapt/modify if needed… Dont have much exp with non-us forecasts so it might be slow
Tony -added a link to the UV/Solar images (first post) and the moon icons.. There are 2 other files moon2.png and sun2.png which are in the zip you need to put in your ajax-images.And HOLY UV there. wow… thats high!
I have those png icons uploaded now but the only icon I cannot find is SH-moon28.gif have all the others.
I am using the WXSIM forecast here and will need to modify the cell forecast.
As for the UV here it gets very high here , burn very quickly. (that ozone hole right above us). Plenty of “slip,slop,slap and hat” 8)
