I have a little time available and I want to upgrade my version from 3.2 to 3.4 (or should I wait for 3.5?)
Getting everything configured and running correctly was very difficult and required several trips to this forum. The question is: if I upgrade versions, do I need to start all over again with configuration, or are all of the variables stored in the .ini file and will be read (and not overwritten) by the 3.4 version?
(Speaking of the .ini file - for Unix uniformity, you should consider renaming the file to something.conf)
Something happened to my WD after the Hurricane with shutting down and rebooting and all that - now my delandwx.html is not updating, nor is the image (see www.koipond.org). I changed nothing in the config to cause this to happen.
I’m also making another run at getting WD Live going. I’m having to backtrack to a few months ago when I was deep into this – my clientraw file is not updating. I think I remember that WD produces this and WD live uses the file, but I’m not sure. Any help here is greatly appreciated.
You are the man - that worked. My .html file is still not being generated - guess I’ll have to play around with that. I’ll go ahead and upgrade today to 3.4
Success - got everything upgraded. I even got WD Live going - at least locally. Do me a favor please and see if the link to the live weather works for you. I just used my local 192 IP address for the domain name in WD Live config. (www.koipond.org)
Still can’t figure why my WD html output doesn’t work anymore.
The weird thing is that I have not changed any config stuff since the hurricane blasted through here. My last delandwx.html update was Sept 5. Go figure :?:
Hooray - WD Live works then! I need to send Julian (and Brian’s overdue) a little money.
The reason you didn’t see the link to WD Live was probably due to your browser’s cache. I just updated the page… I don’t remember if I have have a “no cache” statement in the web page.
go to setup, control panel, ftp/internet setup, custom web page setup, and turn off the custom web page option
as wd is expecting to find a wxlocal.html file to convert to ws.html and to upload that file
nope, it would not have happened by itself
you must have turned that on at some point, but it would not have got set until you restarted WDS
honest.
(windows users have made the same mistake, beilieve me)
I need to fix the switches so its easier to see if off or on , on the linux version
working on vers 3.7, will be ready in less than hour…for you to use, to get all the features of wdl working
when you shut down, do you actually choose to save and exit WD? because I have noticed if the power goes out without me saving it, sometimes the settings are lost
