Quite happy with my set up now, but I see I can get it to take a picture every, say, 10 seconds, but when it stitches them together, it only uses the ones taken on the minute, so if I have fast moving clouds they kinda looks jerky.
Ideally I’d like to take a snap every 10 seconds and then stitch all those together to make the all day video a little smoother.
I personally an not worried about the Size of the file, currently the all day is about 2.5mb, so even if it went up to 10mb in size is not an issue, maybe an issue to people wanting to download it, as my adsl is only 1mb up, but then its more for me to view and not concerned about the up/down speeds and as ISP’s get quicker it wont be a problem, and its going to take a while to fill a 2tb disk !
I am just Robocopying them off to another location every few weeks to keep things tidy…
Ok tried first and second updates and I cant get it to update the web site, its stuck on the day before I installed the update, so not sure whats going on with it or what I may have missed
Just looking at it now and the time stamped files are not being updated, I look at an xxxxjpgwebcam and it says modified today at 08:05 but I look at the actual picture and its from 2 days ago?
strange as the only pictures created correctly are the ones on the web page the animated one and the current picture, all the ones from the drop down menu are from before I installed the new zip file, and going through the directories although they say modified at the correct times the actual pictures are not the current ones
in the new all day video setup I have the following
first box is set to c:\wdisplay\webfiles\webcam\jpgwebcam.jpg
second box c:\wdisplay\webfiles\videos
video format is .flv
and currently ticked all the boxes to see if that makes a difference, the above setup is the same as webcam video setup page
so you have set the folder to save the time stamped files as
I tested setting a different directory for where the time stamped files are saved to, as where the non time stamped file is sourced from
and that worked
do you have the enabled setting set? (right hand side, under the save settings)
can you post a screen shot?
