Hi all weather friends,
I would like to ask which file is the forecast log file in which log all the data last forecast uses. An example of what i was seeing before but i dnt know why i cant find this file again. Now i have the problem not know which data (gfs run) wxsim using!!! i think i need tick any box or file change name from older versions.
Thank you in advance
Vassilis
Clicked Get Data
Get surface data for home site
SYNOP
Found 2 SYNOPs
RAOB
Found site 1 for
Found site 2 for 12Z 4
Found site 3 for 11Z 4
READY or GFS
Found for 04-12Z
Wind factors: FOUS = 83, READY/GFS = 83
Name of imported file = C:\wxsim\wdata.txt
Date now = 11/4/2007
Time now = 9:32:07 PM
Site = Larissa
Model date = 11/4/2007
Model time = 1200Z
Standard time
Temperature = 17.2 C
Dew point = 12.9 C
Sea level pressure = 1016.3 mb
Wind 0 km/hr from 0
Sky cover by level: 88 0 0 0 0
Cloud opacity by level: 4.5 0 0 0 0
Wind direction by level: 268 250 233 255 262
Ozone = 300 Dobson units
Auto cumulus
Dew = def
Haze = 1.2
Fog = def
Urban heat island effect = 47
1-Click
Adjust upper air toward RAOB
Upper air adjustments (C) by level: -2.3 -1.6 -3.0 -4.5 -6.8
Changed maximum range to 1000 miles, or 1609 km
Cyclonic/anticyclonic changed to 0
Clicked Neutral
*Changed wind direction to 0 *
Neutral Advection
Neutral Fit
Cyclonic curvature = 0
Advection site effective wind speed = 0
Advection site percentage given direction = 0
Clicked Use 850 mb RH
Clicked 0% L1T Use
Clicked 50% L1T Use
Advection prompt for direction changes greater than 45
Reduce superadiabatic
Precip in form of showers
Use 850 mb RH
Clicked Use Model Data from READY or GFS
Clicked 0% L1T Use
Clicked 50% L1T Use
Use 850 mb RH
Clicked Neutral
*Changed wind direction to 93 *
Neutral Advection
Neutral Fit
Clicked Neutral
*Changed wind direction to 256 *
Neutral Advection
Neutral Fit
Clicked Neutral
*Changed wind direction to 332 *
Neutral Advection
Neutral Fit
Clicked Neutral
*Changed wind direction to 32 *
Neutral Advection
Neutral Fit
Clicked Neutral
*Changed wind direction to 130 *
Neutral Advection
Neutral Fit
Clicked Neutral
*Changed wind direction to 215 *
Neutral Advection
Neutral Fit
Clicked Neutral
*Changed wind direction to 273 *
Neutral Advection
Neutral Fit
Clicked Neutral
*Changed wind direction to 360 *
Neutral Advection
Neutral Fit
Clicked Neutral
*Changed wind direction to 110 *
Neutral Advection
Neutral Fit
Clicked Neutral
*Changed wind direction to 35 *
Neutral Advection
Neutral Fit
Clicked Neutral
*Changed wind direction to 349 *
Neutral Advection
Neutral Fit
Clicked Neutral
*Changed wind direction to 281 *
Neutral Advection
Neutral Fit
