I have just updated from build 47 and the tide predition worked fine on weather display and uploded to web site untill I updated to build 87 .
Now I have updated I get the following screen in weather display and on web site.[/b]
Usage:
wxtide32 [-24] Use 24-hour time, not AM / PM
[-append] Append - WXTide32 to end of window name
[-autokt] Auto change knots^2 to knots
[-autosave] Save changed options and window positions on exit
[-banner] Sideways ASCII tide graph
[-bgday …] Background color for day time
[-bgnite …] Background color for night time
[-bmp {filename} Name of BMP file to generate from graphics window
[-calen [N]] Make month tide calendar for N months
[-calib] (Hairy) Tick marks at top of the hour
[-caption] (Graph) Displays station name at top of window
[-check YYYY] Check for errors in equilibrium arguments
[-config {filename | -}] Read configuration file / stdin
[-cur] Restrict -location search to currents
[-custname “name”] Name of custom station, only used with custom
station offsets (-htoff, -hloff, -ltoff, -htoff)
[-datemdy] Shows dates as mm-dd-yyyy instead of yyyy-mm-dd
[-depthlines] Shows depth lines on graph
[-fgfall …] Color of ebbing water
[-fgmark …] Color of mark line
[-fgmapdot …] Color of tide station dots on locator map
[-fgmcudot …] Color of current station dots on locator map
[-fgmiddle …] Color of middle line
[-fgmllw …] Color of mllw line
[-fgrise …] Color of flooding water
[-fgtext …] Color of text and lines
[-graph] Main and Text Mode is graph tides
[-gstart YYYY:MM:DD:HH:MM] Time at which to start graph or text
[-gstretch N.NN] Adjust graph detail vs. time span
[-hairy] Main Mode is centered tide graph
[-help] Send usage to standard output
[-hfile …] Location and name of harmonics file
[-hinc [N]] Label depth marks in increments of N
[-hloff [{-|x}]N.NN] Tide level offset for high tide
[-htoff [-]HH:MM] Time offset for high tide
[-iconstyle N Style of tooltray icon 0:line, 1:arrow
[-incremental [minutes]] Show incremental tide levels
[-indexfile {filename} Name of index file
[-list [N] List all locations in index N1=DMS, N2=DMMmm
[-lloff [{-|x}]N.NN] Tide level offset for low tide
[-location “Name”] Location to show tides for
[-loctz] Try to use time zone of location (Moof!)
[-ltoff [-]HH:MM] Time offset for low tide
[-mapcues [N] Enable map station cues, 0=None, 1=Hover, 2=fast
[-mapgrid Enable WVS map grid lines
[-mapmpy Station map initial zoom multiplier (0-4)
[-mark [-]N.NN] Draw line at specified tide level
[-marklevel [-]N.NN] Sets mark level independent of -mark
[-maxmru N] Max most recently used entries saved (0-9)
[-middle] Draw line near mean tide level
[-mllw] Draw line at mean lower low water level
[-moon] Show moon phases on graphs
[-nearest LAT LON] Auto-selects nearest station to Lat/Lon (D.MMmm)
[-nofill] Line graph instead of filled-in graph
[-nolines] Suppress tick marks / depth lines
[-now] Show current time / mark place on graph
[-nowarn] Suppress big ugly warning message
[-numdays [N]] Number of days of text tides
[-nummonths [N]] Number of months of calendar tides
[-onedate] Graph mode declutter to show date once
[-onesc N] ESCape key action is 0:None,1:Minimize,2:Exit
[-onlyone] Only allow one instance of program
[-onlytcd N] Only show binary TCD file locations when N=1
[-overview] Selects overview graphics mode
[-ps] Generate PostScript[tm] output
[-raw YYYY:MM:DD:HH:MM [HH:MM]] Raw output from gstart to time, opt step
[-scrollbar] Show time scrollbar in graph mode
[-skinny] Trim the fat, make window tall and skinny
[-showlevels] Show tide levels on graphs and clocks
[-stats YYYY:MM:DD:HH:MM] Find stats from gstart to this time
[-stagger] Graph mode declutter, staggers high/low tide times
[-staggerfloat] Graph mode declutter, tide times float on tide
[-subproc N] Set subordinate proc to 0:Fast, 1:NOAA
[-sunmoon] Show sun/moon rise/fall on text tides
[-test [N]] Test mode (mostly useless)
[-text [N]] List N tides
[-textascii [N]] List N tides / select ASCII graph mode
[-textfile filepath] Redirect text output to file, -nowarn inhibits msg
[-thin] Leave out year and time zone
[-tinc [N]] Label each N hours
[-toooltray N] Animated icon 0:None,1:on Minimize,2:Always
[-toplines] (Graph) Depth lines on top of graph
[-tz [-]HH:MM] Fixed time zone offset for timestamps
[-units {ft|m}] Convert units where applicable
[-userfile {filename} Name of user station index file
[-utc] Show timestamps in UTC
[-uutc] User’s times (gstart, etc.) are in UTC
[-version] Print WXTide32 version
[-weekday] Show day of week in printed dates
Time format example – half past midnight, June 1, 1995: 1995:06:01:00:30
Colors are specified as rgb:hh/hh/hh (where hh is a 2-digit hexadecimal number).
Hi Budgie,
I loaded the main weather display install file v 10.37Q build 87.
Version on 7 November 2011 - 20:04:43 24.61 MB
From Weather display download site.
When I reload Build 47 eveything works OK
try editing that .bat file
with notepad.exe
and see if you can get the error stopped
(i.e Manually run it)
also
compare that file produced with build 44
I have renamed the old directory and reinstaled build 87 & tide program.
Now they both work OK. (BUT) if I unzip the backup from databackup112011.zip the fault returns.
I don’t want to lose the last 12 month records and info, so which files and from which directorys do I need to copy back to get last 12 month data.
If you have the backups switched on then WD will amend the backup112011.zip by itself with the latest settings & data so there shouldn’t be a requirement to backup anything else.
Yes I assumed that, but like I said if I use the copy from the old directory build 47 it corups the tide page on the new setup.
I would like to retrieve as much history, month on month etc as I can off the build 47 version then do a backup.
At the moment I have no history from the last 12 month on the build 87.
I have copied the 3 complet directory’s across DATAFILES - WEBFILES - LOGFILES
Most things seem to be OK, having a bit of bother with WDL if I live preview it in the program all the graphs and records seem OK, but on my web site they are there but show different data.
Is the Real Time FTP running to upload the clientraw files?
Look in the task bar, near the clock, on your PC and see if there’s a grey & yellow icon with red “FTP” on it.
If this is running then double click on it and see what’s happening.
Yep it seams to be running OK see below.
Dials are moving and are the same as the WD and the counsel and the Rainfall Last 31 Day seams OK, Rainfall Last 7 Days is showing non when there was rain, Rainfall Last 24 Hours is showing rain.
Strange Eh.
200 Using ASCII mode to transfer data.
Uploading file C:\wdisplay\webfiles\clientraw.txttemp → / clientraw.txttmp
PASV
227 Entering Passive Mode (81,169,145,47,96,4)
STOR clientraw.txttmp
150 Opening ASCII mode data connection.
226 Transfer complete. Closing data connection.
File uploaded at time :15:10:38
RNFR clientraw.txttmp
350 Awaiting destination name.
RNTO clientraw.txt
250 File renamed.
Sheduled log off from real time ftp, will re login
Reseting the FTP
ABOR
225 ABOR command successful.
QUIT
221 Goodbye.
Disconnected.
Connecting to FTP server.
Connected.
220 Speak friend, and enter
USER [email protected]
331 FTP login okay, send password.
PASSWORD=****
230 User logged in, proceed.
TYPE A
CWD /
250 Directory changed to /
CWD /
TYPE A
PASV
227 Entering Passive Mode (81,169,145,47,146,111)
File uploaded at time :15:10:48
RNTO clientraw.txt
250 File renamed.
TYPE A
PASV
227 Entering Passive Mode (81,169,145,47,152,174)
File uploaded at time :15:11:3
RNTO clientraw.txt
250 File renamed.
surprised that build 87 is causing problems
if you have a USB data logger then make sure to be using the latest silicon labs driver
you still could get those lock ups with build 42 if you do not upate to the latest driver
Hi windy thanks for bearing with me with my problem.
I am using XP Pro with a USB Serial Port (COM4) with a Technoline WS-2350 data logger.
Can you be more specific with witch silicon labs driver I should download the name or whatever, please.
The one on my system at the moment is.
Driver Provider : FTDI
Driver Date : 18/03/2011
Driver Version : 2.8.14.0
Didital Signer : Microsoft
I typed silicon labs driver in google and its like a mine field.
I don’t want to knack everthing up as Build 42 is still working fine no lockups.
As you didn’t have your station type in your profile, Windy thought you had a Davis VP2 station.
As you have a WS2350, with a built-in datalogger, the Silicon Labs drivers are not needed, they are for the Davis Weatherlink Dataloggers only.
