Author Topic: Moving WD windows XP to 7  (Read 1398 times)
Offline cbjg
« on: October 27, 2011, 10:28:51 AM »
I follow this topic step by step
http://www.weather-watch.com/smf/index.php/topic,9234.0.html
but unfortunately for me it doesn't work
previous WD is installed on c:\wdisplay
and the new one in the same c:\wdisplay
Any idea?
thanks for your help
Basstudio
  • Guest
Re: Moving WD windows XP to 7
« Reply #1 on: October 27, 2011, 11:18:59 AM »
I did exactly the same thing but over a year ago and it worked for me.
What is not working?
Offline cbjg
« Reply #2 on: October 27, 2011, 01:01:30 PM »
Software is still unregistered.
thank you for evaluating.....
Offline JaxWeather
  • Bob
  • Global Moderator
  • VP 2 w/FARS - WML Station: WD00007
  • Jacksonville, Fl. USA
    • JaxWeather.net
« Reply #3 on: October 27, 2011, 03:41:38 PM »
You did this step?
Quote
Then, still on the new computer, go back into the databackup folder. Find a file called "wdisplayftp.reg" (it will say "registration entries"). Simply double click that file to execute the registry entries.
Double clicking the wdisplayftp.reg is what should set your registration and stuff up?  Also what version WD?
Offline cbjg
« Reply #4 on: October 27, 2011, 04:14:21 PM »
Double click doesn't solve the problem
WD 10.37Q b80
Offline niko
  • syzygy
  • Global Moderator
  • Northern California, U.S.A.
« Reply #5 on: October 27, 2011, 06:01:53 PM »
Is it working apart from needing to hit OK on the thank you for evaulating nag screen, and on the expiration notice popup? If so all you need to do is request a new registration code. Hit the register item at the top of the screen, and follow the instructions, be sure to include your original registration info in the email that you are instructed to send.
