Author Topic: Setting permissions and running a cron program to check for errors/debugging  (Read 8274 times)
  • Davis VP2
  • New Zealand
    • Weather Display
from a terminal window (see under applications, utilities)
first type
cd /../ (then hit enter)
then
copy paste the line below into that terminal window
sudo chown -R root:admin /Applications/WeatherD.app
(then hit enter)
(then enter your password when prompted)
sudo chmod -R 775 /Applications/WeatherD.app
also do the same for
sudo chown -R root:admin "/Library/Application Support/wdisplay/"
(then enter your password)
sudo chmod -R 775  "/Library/Application Support/wdisplay/"
you need to run this from the root
and you may need to enclose the directory in " "
i.e
To run a cron program from a terminal window, to check for errors for debugging:
cd /../
cd /Applications/WeatherD.app/contents/Resources/
./cronftpreal
« Last Edit: August 07, 2012, 09:03:13 PM by Weather Display »
Offline wellsweather
  • Well, Somerset, UK
  • Mac OS X 10.7
  • Firefox 13.0.1
    • Wells Weather
password
what password???
Offline bhogsett
  • Cleveland, Ohio, USA
  • Mac OS X 10.7
  • Firefox 13.0.1
    • BoatHouse Weather
password
what password???
You should be prompted for a password after you enter the sudo command.  I think that if you have already provided the password you will not be prompted a second time.
  • Mac OS X 10.7
  • Firefox 13.0.1
    • Wells Weather
Thank you
Offline justme
  • Mac OS X 10.11.6
  • Chrome 51.0.2704.103
I am trying to open the latest WD version for mac [Weather Display For Intel MAC OSX10.8 and above v 10.37Mac Build 272] but the blue progress line stops at about 75% when the display reads "Cron files location......" and the the display closes abruptly.
I have followed the Terminal instructions as above and have copied the result below.
What am I doing wrong - or what should I be doing?!
Thanks in anticipation......
Last login: Sat Sep  3 00:24:56 on ttys000
[Peters-iMac:~] PMC1%
  [Restored 5 Sep 2016, 22:11:34]
[Peters-iMac:~] PMC1% cd/../
cd/../: Command not found.
[Peters-iMac:~] PMC1% cd /../
[Peters-iMac:/] PMC1% sudo chown -R root:admin /Applications/WeatherD.app
Password:
Sorry, try again.
Password:
[Peters-iMac:/] PMC1% sudo chmod -R 775 /Applications/WeatherD.app
[Peters-iMac:/] PMC1% sudo chown -R root:admin "/Library/Application Support/wdisplay/"
[Peters-iMac:/] PMC1% cd /../
./cronftpreal
[Peters-iMac:/] PMC1% cd /Applications/WeatherD.app/contents/Resources/
[Peters-iMac:WeatherD.app/contents/Resources] PMC1% ./cronftpreal
program execute location ./
location of ini files via location.txt /Library/Application Support/wdisplay/
Client raw FTP Upload 22:14:42 5-9-16
FTP real vers 3.8
custom flag
client raw location from ini file  /Library/Application Support/wdisplay/webfiles
clientraw name =clientraw
Not Using file rename
Port to use 21
Passive mode on
1 3
2 3
3 3
4 3
An unhandled exception occurred at $00012B0A :
EInOutError : Access denied
  $00012B0A  PASCALMAIN,  line 277 of /lazarus/projects/newWD/cronftpreal.lpr
  • Davis VP2
  • New Zealand
  • Win NT 10.0
  • Chrome 52.0.2743.116
    • Weather Display
try
move the folder
to
/Users/[yourusername]/Documents/
then delete the folder in application support
