How does WD uninstall? I need to start over but I don’t see it in the package list :? (Unbuntu)
just deleting the folder where its installed to (and any subfolders) should be enough
OK, I’ll give that a try.
Hmmm, so I deleted it all. Downloaded a fresh one, extracted and installed it and I have the same problem, no menu :oops: This is the latest Ubuntu.
You shouldn’t have to install it. I just downloaded it, extracted it, switched to the folder /wdisplay and run WeatherD.
Randy
My WeatherD doesn’t run. I was following other posts on here that say to run GoWeather.sh.
if you try to run from a console window, where WD is installed to
as
./WeatherD
what error shows up?
mine doesn
I’ve been trying to test WD under Linux for a few months now on and off. My problem is that I wanted to use TCP/IP connectivity to VirtualVP but when I open the control panel for the connection the TCP/IP section for VVP is blank. Does Linux WD (GUI version) not support this now? Can anyone else confirm that this panel is blank?
No not that one, its on the Com port selection screen, there is a tab for it.
Stuart, just checked and mines blank too.
admin2@ubuntu:~/wdisplay$ ./WeatherD
./WeatherD: error while loading shared libraries: libusbdll.so: cannot open shared object file: No such file or directory
That’s what happens when you run directly because it has not added the library which is what the script does. Right now I have a different problem where WD wont run, so I’ll open a new thread for that once I’m sure it’s not me!
Niko, you will need to first copy the library files to
/usr/
broadstairs, I have not had a chance to look into the TCP/IP yet
So just the individual files from deploy into /usr/ ?
yup
actually to
/usr/lib/
if you run
./GoWeather
then that sets your environment library path (LD LIBRARY PATH) to check in the deploy folder for the library files
OK, I copied the files, so now there’s no error for ./WeatherD - but the WD window (oops can I say that here?) still looks the same, no menu line
thats odd…I have not seen reports of that particular problem before…
Yeah, I searched and didn’t find anything even similar :dontknow: Oh well, plenty of other projects to play with…
