I don’t think deleting the file is so bad, it’s a work around for a “feature” that the author of guvcview thought would be valuable. What cam do you have?
I found reference to uvccapture http://www.quickcamteam.net/software/linux/v4l2-software/uvccapture that apparently overwrites the captured image.
Not at all, it was a fair comment. Just so happens I don’t use WD’s functions for my webcam, you probably would find my (windows) scripted solution very inelegant too, but it’s worked troublefree for years…
Sounds good to me If you want to add weather data on the website pic you can use the 642weather.com php script.
It’s to be found here: http://www.642weather.com/weather/scripts-image-handler.php the author, Mike Challis, has good documentation, it installs/runs on your webserver. It gets the weather data from a file uploaded by WD (I believe the linux version will do that part).
Not sure of the context but on here it normally means a movie generated from multiple snapshot images, IOW a time lapse, nice to show development of storms, dawn, sunset etc. Scroll to the bottom of the author’s page for examples http://www.weather-display.com/windy/gb/grahamsbeach.htm.
its not all that clear exactly what you are trying to do?
if you are simply wanting to upload a web cam image file to your web site
then use the
control panel, ftp/internet setup, web cam
select the file
click add to add to the list
then tick upload these files as well
set the times to upload
and turn the switch on
I just tested that here, and it works
I sent you my latest answers. Are you going to move those messages out here?
Randy
BTW, I tried putting a sticker in my signature, but it’s not coming through. I really want something like Brian has. Do you know how I create one of those?
Randy
Here’s the code for mine, just substitute your url and image url:
[url=http://www.realweatherstation.com]
[img]http://www.realweatherstation.com/wxs/sticker.php?type=banner[/img]
[/url]
Got it! Thanks.
Randy
Setting up your own weather website using WD for Linux.
Warning: WD is a very powerful piece of software and can do almost anything you want it to do. However, in my opinion, it is haphazardly organised (not a criticism, just an observation) and poorly documented (this has traditionally been one of the downsides of Linux projects). This means that if you are a beginner or an intermediate in Linux, you are likely to spend a helluva lot of time just finding out how things are supposed to work - at least that was my experience. This tutorial is my attempt to be part of the solution and not part of the problem.
Here are the things I wish I knew before I started the project.
a) WD is powerful and can do what you want…if you can find out how.
b) There are far fewer commenters on these forums than you would hope - so help is not always at hand.
c) You need to set up a static file somewhere called something like image.jpg. This will be a static file and to this name, you will post your webcam shots. This static file will then be uploaded on a regular basis (set by you) to your website and to WeatherUnderground (if you so wish). You will have to point WD and WU at this file.
d) There does not seem to be a program in Linux which can take webcam pictures at regular intervals and post them to a static file name. Work arounds are required.
e) Whatever solution you come up with, it will not be elegant. HT niko
- Get yourself a website e.g www.xxxweatherxxx.xxx
- You can get this from GoDaddy. I have stolen the following from various posts by niko.
Following (and stealing from Bob), Creating a basic web page FAQ
Where Bob’s FTP/Internet set up is for Windows…the attached is mine for Linux.
Follow Bob’s instructions and fill out this page. Note there are duplicate numbers on Bob’s page…focus on the blue numbers that have arrows attached…ignore the ones with no arrows.
My generation time window is shown attached…again follow Bob’s lead…but ignore again the blue numbers with no arrows.
Now you will be taken to 3 web page set up forms. As each of these posts has a maximum of only 4 attachments, I will to the next post to show my 3 forms.
Here are 2 of the 3 set up pages (max upload for all attachments is <200k…so, sorry will have to attach the third on to the next post). Note the first page of your website must be called index in e-rice. WD produces a file called index if you call your website index as in the attached screenshot. If your first page is not called index, then your information will not load.
Next we will tackle the webcam.
Niko says in one of the posts that setting up the WD component of the website i.e. the data was straightforward, my experience is that, yes in hindsight it is …but it was far from obvious and straightforward at the time…and I think that had to do with lack of documentation and leads…hopefully this tutorial will go some small way to remedying that.
My biggest problems were a) working out that you needed a static file name that WD and WU could link to b) finding a way of creating a static file name c) having a tick in the wrong place in one of the innumerable boxes on the webcam form stopping my jpg from loading.
Setting up the camera, for me, came in two parts.
setting it up to connect to my website
setting it up to connect to Weather Underground.
Regarding 2, here is a post from jloflin
OK, I’m going to try to piece this together. It took me many months of fiddling with settings. First, are you capturing images to your /wdisplay/downloads/ directory? That was my first problem, figuring out how to get my webcam to send images to that directory every minute. Then I made sure the images were named “snapshot.jpg”
Next, I opened control panel. Under “Web Site Configurations” I opened Web Cam. I clicked on “Load/Set Webcam Image File” and went to the /wdisplay/downloads/ directory and chose “snapshot.jpg”. Then I closed the Web Cam panel, using the check button.
Then I opened FTP & Connections. Under the Webcam tab, I clicked the “choose webcam file” button and navigated to and chose the “snapshot.jpg” file. Then I clicked the add button. I then closed the FTP & Connections panel, using the check button.
Next, under the “Station Settings” heading, I clicked on “Summary Images & Icons”. Under the “Use Webcam for Icon” I checked “Use the Webcam Image as the Icon”, “Show on Main” and “Stretch to Fit”. In the “Select Webcam Image to Use”, I clicked on the “Select Webcam Image to Use” button, navigated to “snapshot.jpg” and selected it. Then I clicked the “Use this Filename” button. I then closed the window with the check button.
Viola, within about 5 minutes, I had my webcam image as the icon on my main page.
I hope this helps. If you need, I can try to send you some screenshots of the windows and tabs I used. The only Webpage I’m uploading to at present is Weather underground page for my station at zip code 79912. I’m almost afraid to begin the effort to upload to a personal web page.
The snapshot.jpg is downloaded to my computer by the webcam’s control program (I use a panasonic camera and its embedded control software). It downloads once per minute, replacing the old file with a new one. One of the options in the control software is to just replace the file, and not to number them. Wdisplay just takes the file that it finds.
I’m uploading to Weather Underground the same snapshot.jpg that Wdisplay is using, but at 5 minute intervals. I chose the ftp method, and complete all the information requested on Weather Underground. It then gave me a camera name. In Wdisplay, under “Control Panel”, click on the Weather Underground icon. On the Weather Underground panel, click on the button to set up webcam uploads. In the FTP settings, the username is the name of your camera on weather underground, not your login name. Mine is randyloflinCAM2. The password is the same as your login password. The image file is the same one you use on your main page, mine is /wdisplay/downloads/snapshot.jpg. Select your upload times, turn the red button green and check the save button, close control panel with the save button, and you should be good to go. Now when I look in /wdisplay/downloads/, there is a wunderground.jpg file, which I presume is the one wdisplay is FTP’ing to weather underground.
- Go Control Panel > Web Cam
- concentrate on page 1 web cam set up…ignore all other pages…all you need worry about is your static file name and location. Don’t waste time on time stamping etc.
- see attached for how my set up looks. I had to crop it as the file was too big to upload…but I think you get the message. If you are linked correctly to your static file (set the webcam file image), the picture should show here. My static file image is called image-1.jpg.
Next you have to go to the FTP & Connections (that is what it is called on the Control Panel) thought the title of the window is FTP/Internet set up. This is the kind of thing that drives me crazy…lack of internal consistency…and different parts in different places…something this bitty needs some kind of trail…otherwise, newbies spend inordinate amounts of time trying to piece things together…and often just give up in frustration.
Here is my WebCam/FTP set up. I had accidentally ticked the box “use this remote directory instead” and spend days of frustration wondering why my jpg would not upload.
