Web hosting: where to host your weather page
Thanks for the input :slight_smile: I have a couple at Register.com but I’m having a hard time understanding what I’m getting for the extra $$, especially for a hobby.
Ok, stupid question time…
Should I get the domain name first and then the hosting site or get the hosting site setup and going then link the domain name?
(I know it’s pretty green question but I haven’t owned a domain name is 3-4 years. :lol: )
Here’s what I would do:
a: Register the name - then you’ll be sure what it is
b: Sign up for hosting, they’ll need to know the name from “a”
c: Go back to the registar and give them the DNS IP addresses you’ll get from the hosting co in step “b”
d: Wait maybe 24-48 hours until the DNS info propages across the net and then you’ll be able to see your site.
All of my domains are with GoDaddy.
At work, we have about 30 or so with Register.com. Only two of them are on their “primary” servers which means if I make a change they are supposed to update the server within 15 minutes. These have 1 hour TTL time. The rest are on their “Free” servers which can in theory take up to 47 hours to update (both update once every 24hours 12 hours appart).
The only reason why the corp is with them is due to some of the other country support. Otherwise, I would move them all over to Godaddy.
At $43 per year for the privledge of Register.com… I’d stick to Godaddy.
A 1 hour TTL will be increasing the DNS traffic quite considerably. I tend to set 24 hour TTLs on the grounds that DNS changes are rarely needed and usually planned well in advance, so you can reduce the TTL a few days before the change (to 15 minutes last time I did it) to get a quick change once the server IP is changed and then change it back to 24 hours once you’re sure the change doesn’t need to be undone.
There have been recommendations for www.godaddy.com for low cost domains, but I haven't used them (yet).
This site seems to have vanished I have been trying for several hours!
Anyone got any addresses for cheap domains? :smiley:
godadday works fine for me
just tried it
Just registered my domain name with godaddy.com … was very easy.
My wife thinks I should add a link to the city (www.cityofcarterlake.com) right on the main page because I have a better domain name then they do now.
it appears to be back. I just tried it
http://www.godaddy.com/gdshop/default.asp
One note here for those who still aren’t convince to buy a domain name.
Godaddy (and I’m sure others) allows you to redirect/mask to your current hosting site for free.
I’ve decided to go this route at the moment, while continuing to use my ISPs free hosting option for the site.
So when you go to www.carterlake.org, you are really going to http://members.cox.net/carterlakeweather
Advantages:
  1. Everything stays free
  2. No hassle domain name (takes mere minutes to setup!)
  3. Can register domain name with search engines
  4. Previous visitors notice nothing… all links still function as before
Disadvantages:
  1. Creates another layer which needs to be working for site visits (i.e. godaddy.com goes bye bye and no visitors through domain name even though site is up and working)
  2. Masking masks refer stats (I can no longer tell where people are coming from)
  3. Unable to bookmark individual pages
  4. Possible page rendering glitches with Firefox (looking into work arounds for those)**
** Got that working again… had to change some of my Javascript to be WC3 compliant
Update: It is now 24 hours later and it appears that “godaddy” has indeed gone, still can’t raise the site, has anyone else been able to? :frowning:
i think its just you that has trouble with that site oldun, on your slow internet connection, maybe
just tried it here again, no problem
Works fine for me, and it was working last night when I saw your first post. Have you changed anything with your browser that could be blocking it?
You’ll end up on a secure page anyhow, so try https://www.godaddy.com/ or https://www.godaddy.com/gdshop/default.asp
Does your Internet provider offer similar services? Is it possible they’ve blocked access deliberately?
Even if they do provide the same type of service, bocking another Registrar would be a violation of ICANN rules. One registar cannot block access to another. It would be foolish for a Registrar to do that.
My guess is that it is network routing related. There have been a lot of overseas networking issues the past couple weeks.
once Ambient thought i had insitaged a DOS attack (yeah right, with a dail up 28k connection?)
and they blocked my IP address…but it was only assigned from my ISP, and so all users of the ISP I was using could not get to their web site.
That’s a common problem. A server in the hosting facility and in the same Class C sub-net as my server got hacked and was being used as a spamming agent. At least one of the big spam blacklisters blocked the complete Class C net which caused me some problems!
Now I can answer my own question, yes it did!
I transferred one from Register to godaddy. Took from Saturday afternoon to Monday afternoon. Very smooth, just had to ignore godaddy’s hundreds (it seemed) of offers for additional cost services and register’s tearful entreaty not to transfer, warnings of dire consequencies if I did, and a 30% off renewal offer. Godaddy added a year to the expiration date, hooked it up to the previous DNS addresses and if there was any interruption of service it was very small. :smiley:
I use
http://kiwiwebhost.co.nz/
for my WX site. Only $1.00 per week NZ$
Seems to be very good.
Yep… I would like it much if they toned that down. I wonder how many plunk down more money for that “stuff”.
One other thing… as your domain come up for renewal… you will start getting 90 day, 60 day, 30 day, 15 day… email notices that you need to renew soon… I have them ALL filtered to a mailbox where I dump them since I let the autorenew take place when they expire.
I used to pay off all of the renewals for the month at the first of the month, but I’ve since just let them renew automatically when they expire. A lot less headaches. The renewal is alway for 1 year and at a whopping 8.99 for com and net … its no big deal. sometimes you catch them with a promotion to make it even cheaper.
If only I could convince my primary job employer to swtich over from register.com, my life would be much easier. sometimes I wonder if they actually know what DNS is … I’ve got some real horror stories about them.
