Just started last night. WXSIM generates an error stating “permission denied line 7783”. Anyone have any ideas?
Thanks!
Al
Thanks!
Al
NOw seeing this in WXSIMATE
System.IndexOutOfRangeException: Index was outside the bounds of the array.
at wxsimate.Form1.fullrad()
at wxsimate.Form1.localimport()
at wxsimate.Form1.impdat_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
I found the issue. The 72011lg.txt log file had one line that was indented to the right about 35 spaces. Pulled the blanks out and re-ran WXSIM all seems fine.
Al
Still poroblems. Can someone tell me if my WXSMATE settings are OK
Look to the file attatched.
Thank you
The location for your local data directory is “c:\wdisplay/logfiles”, it should be “c:\wdisplay[color=red][/color]logfiles” (note the \ instead of /).
