I am having problems with WD mixing up weatherdata.
This is a problem that’s coming back for every new month starting.
Recreating files has no effect.
My logfile of Juli 2011 is correct.
FYI Windy, you recently converted a couple of logfiles for me and those were correct.
I am sure, I am recreating the right way and setting parameters correct.
I am using W7 Ultimate Edition 32-bit.
Closed WD and closed W7, then rebooted.
Recreating files still has no effect.
I am on build 47 right now but I have noticed that newer builds have no effect.
Haven’t tried the latest version yet but I don’t think that will make any difference.
Let’s go over to some screenshots I made to explain what I mean exactely.
Menu [View] Averages/Extremes - NOAA Style Reports
[Tab] Averages/Extremes
I couldn’t catch the whole screen, so I divided up in 2 seperate screens.
The list shows days 06 - 29, 01-06
From the top, day 6 until day 29 is weatherdata for the month of June.
Then, Day 1 until day 6 is weatherdata for Juli.
As of 00:00, the first day in the list will be removed (day 6, day 7 will be the first in the list) and another day 7 will be added
at the bottom of the list.
And so on to the end of the Month of Juli.
Finally, the month of Juli will show from day 1 until day 31.
[Tab] NOAA Style Reports
Screenshots were taken on Juli 7.
Notice the entry for day 7! That’s day 7 for the month of June if I am not mistaken.
Day 7 of Juli will only be added to the list after 00:00
Day 1 until day 6 is weatherdata for the first 6 days of Juli, that’s correct.
Meanwhile, all other data at the bottom is wrong.
Notice max rain. 27.0 mm on Juli 16 2011.
We are only Juli 6!!!
The amount of 27.0 mm is correct but for the month of June, the 16th.
[Tab] Detailed Climate Report
Day 1 until day 6 is weatherdata for the month of Juli, thats correct.
All other information at the bottom is wrong and is taken from the weatherdata for June and Juli combined, I guess.
I honestly don’t know what’s wrong here and how to fix it.
Recreating is not an option, it won’t work and the problem is coming back every month.
What I do have noticed is that problem occurrs when different months have been recreated manually.
But like I said, I am very cautious when I do that and make sure I set the right parameters.
Sorry for the long post and it may be confusing but I have tried to describe my problem as good as possible and I hope someone will come up with a fix.
This is very frustrating.
I know, at the end of the month everything will be OK but in the meanwhile during the month your visitors are seeing wrong data
displayed.
TIA
