I can’t get my WD to upload to CWOP even though it uploads to WU fine. I had read around here a bit and it seems that WD either uploads to all or not. Also, can anyone tell me “in detail” where to find the “internet sharing over a LAN” checkbox because for the life of me I can’t find it.
huh?
what do you mean??
WD does correctly upload to CWOP, as long as you have that correctly setup (e.g lat/long is set correctly (maybe if you could post a screen shot of that)
the internet sharing option was removed from the connections setup as it causes too many problems (and its mostly redundant functionality now anyway)
Sorry… I was meaning that I can’t understand why it uploads one but not the other. I know it’s a setting of some sort I havn’t got right. BTW weather link uploads to cwop ok…so it’s just makes it more of a mystery to me. Here are the screenshots you asked for with many thanks.
one thing to check, make sure you have a croncwop.exe program where WD is installed
(e.g via the full install)
and make sure that file is being blocked by the firewall
post here the contents of the
CWOPlogsend.txt
file
I found croncwop.exe ok in the WD folder but according to windows search there is no trace of a file called CWOPsend.txt. Also I have disabled my firewall and tried to no avial. Can you tell me what folder it is usually strored in?
If I click the croncwop.exe file in the WD folder it sends the data and updates the CWOP site instantly (I tested this several times), however if I click the test button within the programme nothing happens…no data is sent. I hope this gives a clue.
ops, the test send does not work, as I had not updated that to use the new croncwop.exe program
in any case, the automatic send should work, at the time you have set to send
try setting a time to send at a different time, i.e set manually a time, say 1 minute from now
also, any errors under view, program event log?
also, is the main switch on in the connections setup in the ftp/internet setup?
(and do you have ticked there to use weather display’s Ftpupd.exe )?
I will check these things when I get home from work tonight. Like all of us I have to work to save pennies for weather stations and stuff. I’ll let you know later tonight. Thanks
I have checked for any errors in the programme log and there is nothing. The log is blank. I tried manually setting upload times and still no cigar. The main internet switch is on, but I don’t know where to find the tick box (Ftpupd.exe) you referred to. Perhaps you can tell me how to find it. Again I am only able to update cwop by clicking the raw file in the programme folder. Everything else is working like a charm.
I found the tick box with your advice and unchecked it. All is updating automatically now so that was it. It’s an option I never knew of or altered so a bit of a trap, but many thanks to you and Brian for sorting it out.
I also am having trouble getting the CWOP upload to work. Am I understanding this correctly? Uncheck this box? Have tried several times over the last couple of years with no success, saw this post and went back to work on it.
I am having the same problem…anybody see what I have set wrong?
Here is the contents of the CWOPlogsend.txt
CWOP data send start 2:43:53 PM 6/28/2011
APRS Connecting to: cwop.aprs.net
Aprs connected
sending pass command
user DW6599 pass -1 vers wx-display 10.37Q31
Sending the aprs data now
APRS data send:
CW>APRS,TCPIP*:@231700z3402.00N/09701.00W_112/007g
012t041r000p000P000b10275h60L0232.WD 31
Disconnecting from the aprs server now
Finished
Thanks for any help on this, Doug
*cwop4 is my weather link set-up
Auto or manual.The data is not showing up at CWOP. The CWOPlogsend.txt changes every update(in auto) but CWOP shows no data recieved. If I double click the croncwop.exe it also will show a change in the CWOPlogsend.txt but still no data. I had been offline from CWOP for over an hour so I restarted weather link. Posted that set up screen shot also, thinking I must have a setting wrong in WD and it might help.
