!st of month 20040801.gif missing - MONTH END PROGRAM FAILS
WeatherDisplay posts Daily Reports page to my weather site (http://www.cuckney.pwp.blueyonder.co.uk/weather/August2004.htm) but every month it does not upload the gif for day 1 of the month - all others go up automatically with out problem.
I cannot find copy of 20040801.gif for this month to manually correct the problem.
Do others see this problem? Any idea how to fix.
My system resets at midnight each day (rather than 6.00)
:cry:
I had this problem until May, since then it disapeared. Which version are you using?
http://www.cuckney.pwp.blueyonder.co.uk/weather/Dorridge.htm
shows that you are using 10.06
maybe please try using the latest version (now a new 10.16b)
I upgraded my software to version 10.16b on 23 Aug to try to solve month end file problem as described BUT disaster the complete program failed at midnight and aborted and I found a Microsoft message in the morning asking whether to send report to Microsoft!
So have missed 7 hours records and the WD software problem is FAILURE.
I am running Win XP Home.
Have others had this problem at month end with 10.16b?
Any suggestions - can I run month end again? I tried update extremes but that did not put month end correct. No posting of Aug 31 in last month’s file
:frowning: Please Help
there seems to be some people still affected by the end of month bug
it was OK for me
anyeone else had trouble?
you could try recreating the august average/extreme to update it via view, averages/extreme, then scoll right down, near the bottom left…
I have recreated August.htm but it still ends on 30th
I now note that Aug 31 has arrived as the first day in September2004.htm!
I suppose I can cut/paste 31 Aug from Sept to Aug? Will this effect any other logs etc.?
:roll:
JohnC
you can do that ok :wink:
