New icons to play with
I’ve basically taken Ian’s icons and expanded on them…
ENJOY!
http://members.cox.net/carterlakeweather/myicons.zip
I have put some new icons together for anyone to use.
http://www.f1fun.com/weathericons.htm
Comments obviously welcome
I just fancied a change in preparation of my Davis VP arriving :smiley:
All the best
Ian D
very impressive :smiley:
very impressive :D
Yup, sure is :D
hey, great work, and thank for sharing with others!
(to use, easiest way is to unzip all to a directory, then under input daily weather, double click the icon to change, and then select the new icon…easy as that)
Wow… motherload of weather icons…
http://www.jdawiseman.com/papers/trivia/weather-icons.html
http://weather.kivlin.net/grabicons.html
Only just spotted these now. Thanks to both icon creators.
Any chance of doing the three missing icons? There doesn’t seem to be an icon for Thundershowers, Sun Rise or Sun Set. I’ve also assumed that ‘Partly Cloudy’ is the icon to match WD ‘Cloudy Periods’. I think all the other icons have matching names apart from this one.
Done.
Not sure I like the sunset icon…
By the way, there are times the original icons will show up no matter what icons you have replaced them with. (Thundershowers being one of them). I emailed Brian about it. Not sure the status.
Thanks for the GREAT and HUGE bunch of wx icons.
:smiley: 8) :smiley:
Cheers
MikeyM
:? Does anybody know if you can customize the icons for the rain conditons in the ‘formownweather’ setup page? I’ve already customized all the others but don’t seem to find a way to change those.
Thanks!
which ones are not showing your own icon (which you load/set from input daily weather?)
that will be a clue…and will solve a problem others have had
Partly cloudy is one of them Brian.
Keith
After replacing the icons in the daily weather folder the WD default partly cloudy still displays. The new icon is displayed in the folder. Must it be changed else where also? I’m using metar downloads for the main display icons.
i think i have fixed the problem with the partcloudy icon
uploading 10.17e now , which should fix that
Many Thanks :smiley:
These icons I made them myself, if someone likes them, they are free:
http://meteoabrantes.no-ip.info/Meteo/myicons
Cheers
H
[http://meteoabrantes.no-ip.info/Meteo/myicons](http://meteoabrantes.no-ip.info/Meteo/myicons)
That’s giving a 404 error here at the moment.
Chris, I think this way there’s no error:
http://meteoabrantes.no-ip.info/Meteo/myicons/myicons.html
Cheers
H
That didn’t work, but I played with a few options and found some icons at:
http://meteoabrantes.no-ip.info/myicons/myicons.html
I like the windsock!
Hi guys…
Got bored this afternoon and built another set of icons…
or link is at the bottom of my weather site…
Help yourself… :wink:
JK
