! Wire snow depth sensor
My WD is b 28
I have a snowdepth sensor in usb port5 connected.
I would like to configure WD to see the voltage output of my sensor and to produce a graph.
Here 2 screen shots to show my settings.
remove all the ROM Id’s you have put in the wrong places
(put the word NULL there instead)
you should only have entered the ROM Id in the snow sensor location only
why did you put the ROM id in all the other locations?
then click on save/rest
then restart WD
(and then see what shows in the restarted separate 1 wire sensor)
Did exactly what you told me to do and stil;l no voltage, see attatched files.
as noted above, the voltage does not now show in WD, as the separate 1 wire reader now handles the 1 wire routines
(I am still to remove the 1 wire setup and routines from in WD itself)
you need to post the info shown in the separate 1 wire reader
Windy
Whant to understand. Is it possible to use the advance graph option in WD to read my snow depth comming from my 1 wire device ?
If yes, can you tell me how ?
Thanyou
yes
via a custom logfile, using the custom snow tags
and the custom graph file
others have all this working
Windy
Can you tell me where i find custom logfile ? I can
you set to create a custom logfile under setup, logfile setup
and put the needed custom tags (e.g time + snow voltage, separated by a space) into the template file you create
and then set the advanced graphs, custom graph, to use that data
