You are using the default climatedata.html template which does not have solar or UV data. You should also update the $start_year, $start_month, $start_day variables in the solar, sunshine hours, and uv scripts to use the date you start recording those values instead of using the default which is the date I installed my solar and uv sensors.
For the dewpoint, wetbulb, and barometric scripts it looks like you set 2005 as your first year of climatedata files, but you have none until 2006.
For those with solar and/or UV sensors, you will need to use a new template to include the solar and UV values in the climatedataout files. In the latest version of Weather Display, a climatedatasolaruv.html is included in the root directory. Copy it to the webfiles directory and rename to climatedata.html and recreate the detailed climate reports for the months that you have been using the solar/UV sensors. A copy of the climatedatasolaruv.html template is also included with the zip file of the detail/summary files.
