I noticed the values in are in the monthly .htm files created by WD, but they don’t appear on the wxhistory.php page. Is it possible to put them in, or can someone tell me what I need to change?
Would you mind giving a link to your website so we can see the issue?
Also, which values in monthly .htm files are not appearing in the wxhistory.php page?
Ken
Hi Ken,
I’m mainly concerned with these values:
Avg daily max temp :8.1
Yes, here is a fix to add to your include-wxhistory.php to display those values:
part 1: find
array('Growing degrees days',5),
array('Frost days',3), # mchallis added 'Frost days' support 04/21/08
and replace with
array('Avg daily min temp',5), # ktrue added 'Avg daily min temp' support 24-Nov-2010
array('Avg daily max temp',5), # ktrue added 'Avg daily max temp' support 24-Nov-2010
part 2: find
// Check for data lines
output_data($value, $LEVEL);
if ($LEVEL == 2 ) {
and replace with
# ktrue added 'Avg daily min/max temp' support 24-Nov-2010
if(preg_match('|Avg daily \S+ temp :|is',$value)) {
$value = preg_replace('|\:|',' =',$value);
if ($LEVEL == 2 ) {
Ken
Thanks Ken, it works perfectly.
For those prefering to just download and go, I’ve updated the WD/AJAX/PHP template distributions with these changes.
Or… you can just download the attached version appropriate for your template.
Use the include-wxhistory.php.txt (renamed to include-wxhistory.php) if your have the English-only Canada, USA, World template.
Use the include-wxhistory-ML.php.txt (renamed to include-wxhistory.php) if you have the Multilingual Canada-ML or World-ML template.
You’ll need to add translations for
langlookup|Avg daily max temp|Avg daily max temp|
langlookup|Avg daily min temp|Avg daily min temp|
to each of the language-LL.txt translation files supported in your template.
Ken
include-wxhistory.php.txt (14.5 KB)
include-wxhistory-ML.php.txt (15.9 KB)
