Author Topic: Wind speed incorrect Weather Display V10.37L - SuSE 11.3  (Read 5490 times)
Offline Hairybum
« on: October 24, 2010, 05:47:40 AM »
I am experiencing an issue with the wind speed (kmh) display in Weather Display program not matching the actual wind speed being recorded by my La Crosse 3600 (out by 3 times actual).  All other data seems to be correct.  I have been unable to set an offset within Offsets and initial rain option as I require a negative offset (-75%).  I am using fetch3600 to communicate with my weather station. Any guidance will be appreciated, thanks.
  • Davis VP2
  • New Zealand
    • Weather Display
Re: Wind speed incorrect Weather Display V10.37L - SuSE 11.3
« Reply #1 on: October 24, 2010, 05:52:33 AM »
make sure you select the correct windspeed units from the fetch3600 data in the weather station type setup
(i.e the units that the open3600.conf file is set to )
Offline Hairybum
« Reply #2 on: October 24, 2010, 06:18:23 AM »
Thanks.  I changed the open3600.conf file accordingly, however the wind speed became even higher, so I shall do a bit more fiddling with it.  Cheers,
Offline Hairybum
« Reply #3 on: October 24, 2010, 08:41:34 AM »
OK, did that with open3600.conf without success - I needed to # out the wind speed units line to prevent errors - readings of 258 km/h when actual was about 25 km/h for example. I have also tried various configurations within WD - Units & Other Settings, and also within Offsets & Initial Rain.  I have succeeded in bringing the wind speed down to about 3 times actual which is much better than the crazy readings.  I would like to get this right as I upload to a few sites and have needed to edit the data on those sites to correct.  Any advice is most welcome.  Thanks.
  • Davis VP2
  • New Zealand
    • Weather Display
« Reply #4 on: October 24, 2010, 07:17:54 PM »
have you set the correct windspeed setting in weather station type setup?
m/s in the open3600.conf file is the default
Offline Hairybum
« Reply #5 on: October 24, 2010, 08:11:20 PM »
I have km/h selected within open3600.conf (hashed # out at the moment) and cannot see within Weather Display - Control Panel - Station Type and Settings where I select wind speed setting under the La Crosse WS 3600 option or elsewhere within Station Type and Settings.  Thanks,
Offline Hairybum
« Reply #6 on: October 25, 2010, 08:58:05 AM »
I have made progress of sorts.  I set the WS3600 weather station display wind speed to show as m/s, then set open3600.conf wind speed as m/s.  I left the setting for windspeed in wdisplay at km/h and the result is close to accurate for the wind speed.  Go figure, but it will do until I find the 'real' problem.  Cheers.
