Author Topic: Custom WD Main Screens  (Read 23355 times)
Offline MGCJerry
  • Ohio
  • Win XP
  • Firefox 5.0.1
Re: Custom WD Main Screens
« Reply #60 on: June 24, 2012, 12:16:39 AM »
I'm trying to use some of these but a lot of things are just completely out of place. For instance on WNCweather.net's settings, my forecast scroller is at at the far right overlapping the rain rate which the rain data is clipped off the edge of WD. For those who are posting your screen setups, what screen resolution are you guys running?
Offline ALITTLEweird1
  • Mark
  • Global Moderator
  • North Bend, WA
  • Win 7/Srvr 2008R2
  • MS IE 9.0
    • North Bend Weather
« Reply #61 on: June 24, 2012, 02:28:29 AM »
Can you post a screenshot showing the issue?
Im using 1920x1080 res.
"Nature can do without man, but man cannot do without nature."
Davis VP2 + VP2 Solar + VP2 UV + Lightning Detector + Logitech Webcam
Offline MGCJerry
  • Ohio
  • Win XP
  • Firefox 5.0.1
« Reply #62 on: June 24, 2012, 12:03:35 PM »
I used to run 1024x768 but changed to 1280x1024 on the server to see the custom screens. The server is set to autologon my "Weather user" and I admin the machine using RPD which "shadows" that user (eg takes over control of the console).
Here is a modified screenshot with the items in question circled and noted.
Also playing with the screen size helps a little but that setting doesnt seem to be "remembered".
Offline kljw
  • Scotland
  • Win 7/Srvr 2008R2
  • MS IE 9.0
    • MM0KTC - Keith's Weather
« Reply #63 on: December 12, 2012, 02:04:55 PM »
K3JAE
what is the chance of you posting the text file, so i can upload and have a play about?
Cheers
Keith
Offline kljw
  • Scotland
  • Win 7/Srvr 2008R2
  • MS IE 9.0
« Reply #64 on: December 12, 2012, 02:09:19 PM »
Paul03
same question as above to you, can you post test file?
Cheers
Keith
Offline Bjørn
  • Ulsteinvik, Norway
  • iOS 6.0.1
  • Safari 6.0
    • Ulsteinvikweather
« Reply #65 on: January 26, 2013, 10:30:37 PM »
One option.
http://www.ulsteinvikweather.com/uw/ulsteinvik.gif
This is done thrue setup meny in wd.
1920x980 res used on a 63 inch tv.
« Last Edit: June 07, 2013, 06:34:17 AM by Bjørn »
virusdunil
  • Guest
« Reply #66 on: June 04, 2013, 10:22:29 PM »
Here's my layout...
it looks like this patterns is common for a lot on people...MaybeBrian could fix it as the default layout :P hehehe
virusdunil
  • Guest
« Reply #67 on: April 18, 2016, 05:00:25 PM »
Long time no...posts...
so heres my latest one hehehe :wink:
