I apologise as this is probably in the wrong section but I wondered whether someone could advise.
I have the National Geographic 265NC Weather Station which comes with EasyWeather V2.0 software that is just horrible to use! Is there any where to download an update for this software or use alternative software compatible with my low end weather equipment?
Many thanks for any advice given.
I believe that’s a station made by a company called Fine Offset and you can use Weather-Display software with it. You can download the fully functional trial version and run it for 30 days, but after that you need to register it. Coincidentally this is the Weather-Display support forum
Regarding running WD with that station you may find this thread relevant…
http://discourse.weather-watch.com/t/47936
thanks Niko and Bob, really appreciate the help and will check out the WD option.
Cheers.
