[SOLVED] WD Twitter issue
Hi guys,
i’ve red a lot of post about this argument but i don’t know why my twitter page doesn’t updated with WD.
I’ve set it like the attachment and i’ve open the port 80 in my router.
Could you help me please?
Many thanks,
Alessandro
Have you allways used your whole email as your username? Mine is just my username.
It should be your Twitter username and password in there. :wink:
Plus it appears from your screenshot that you’re updating once a day, at 11:59PM…is this correct?
Hi guys,
Yes, it’s correct but i’ve pushed the button “Test a data send” but nothing happens!
I’ve inserted my e-mail because i thought that it was the same. Isn’t it?
I’ve tried with my Username “Meteocarmignano” but without success!
Any idea?
Alessandro
Try this as your username… i_fiorentino
My username is Meteocarmignano or e-mail [email protected]
I’ve tried both username but without success!
The ftpupd starts without uploads anything.
Any idea please?
Alessandro
Not sure if twitter is case sensentive or not. Have you tried using all lowercase? meteocarmignano
Hello Alessandro,
Have you ever been able to send data automatically via WD to Twitter?
Have you gone through the Twitter setup (since OAuth became required)
What version of WD ?
Hi Bob,
no, it’s the first time.
No, how to set it up?
10.37P-64
Many thanks in advance,
Alessandro
Alessandro,
You need to make sure that .NET version 4 is installed and then click on the “Twitter Setup” link in the top left of the Twitter screen and follow the directions.
.NET version 4 is a must to setup Twitter…
Thanks Bob,
i’ve installed .net framework and followed the directions.
Now it works correctly.
Many thanks,
Alessandro
Outstanding Alessandro
10.37P-64
I recommend buuld 73: the time on the bottom of the graph is now like it used to be
