Standard 1 is fine for most purposes.
Bob’s right, there are other more expensive options that will (may/should) give you more support if that’s better for you.
Any advice of how to choose a domain name? I would strictly use it for my WD data, but what if I wanted to use it for other things?
Would try and keep it simple and short. Maybe something to do with the town you live in.
Okay. Got my Domain Name registered with godaddy and bought 1 year with e-rice.net. Seems like my Domain Name is already secure. Not sure if there is a waiting period with e-rice or not. What would the next step be? Go into all my ftp settings in WD?
e-rice will send you a confirmation email. Be sure it doesn’t get lost as spam.
Once you have that email you can go into your godaddy account and set the DNS servers for your domain to the e-rice ones. That change can be live in a few hours but can take up to a day to update all around the internet.
If you open your website URL in a browser and see the e-rice placeholder page instead of the godaddy page then everything is ready to go and you can start work on the WD side.
Please tell us your domain name then we can help you better through the setup stages if we can see the page.
Good choice
Just got confirmation from e-rice. Is there a section here that explains the setup in simple layman’s terms?
I still see the godaddy default page, did you set the nameservers in godaddy to point to e-rice yet? If not login to your godaddy account, select goosebayweather.com (may be automatic since you only have one domain), look for a button like “set namesevers” which should lead you to a page like the one below. Set the nameservers to the ones that e-rice specified in your email. After a while goosebayweather.com should show e-rice’s default page instead of godaddy’s and you can move onto the next steps.
Can’t find anything to do with “nameservers.” I do see that my domain is set in e-rice’s domain manager. Not sure where else to go. Hold it. I finally navigated there.
Okay. I set those Nameservers. I was told it may take some time to refresh. I think I’ll call it a night. Thanks for the help. Hope to get back here tomorrow.
The wd side is pretty straightforward.
Good news, I see your domain is connecting to e-rice now.
Bob’s FAQ is a good start, or you can use the wizard in WD.
The information you will need is:
FTP Host: ftp.goosebayweather.com
FTP Username / FTP Password: You need to first setup an ftp username and password in your e-rice member area, those are not the same as your e-rice login.
Path to web files directory: /web
Name servers have been updated now…
http://reports.internic.net/cgi/whois?whois_nic=goosebayweather.com&type=domain
Domain Name: GOOSEBAYWEATHER.COM
Registrar: GODADDY.COM, INC.
Whois Server: whois.godaddy.com
Referral URL: http://registrar.godaddy.com
Name Server: NS1.E-RICE.NET
Name Server: NS2.E-RICE.NET
I see this now…
If you see this page, it means:
This website is not properly configured; OR
This website is not alive yet; OR
This website has been suspended.
Followed the basic instructions that Bob gives. When going to my website now I am getting a 404-Not Found. One possibility is that I did not enter anything in the Remote Directory (on the ftp side) as I couldn’t find any entry from e-rice. That may be my problem? Also, in the FTP log, I notice that all I have is “no errors.” Nothing like what is shown on the basic help. Maybe someone can help me out here.
The remote directory needs to be /web
Just found that. I’m downloading Filezilla Client right now as recommended elsewhere. Not sure where to go from here. I don’t think I’m set up properly to be “uploading now” in WD’s Control Panel.
Now I see that my site is listed as “currently under construction.” Is there some sort of template I need to start working with?
That’s just the default index.html page, once you upload your own it will go away.
Can you post screenshots of your “connections” page from Control Panel, FTP etc. and Webfiles setup #1 from Control Panel, webpage etc.
Also do you have a file ftplogfull.txt in your WD directory on the PC? If so attach or post that too.
