Wxsim 3in1 script
OK, Error reporting added back in, i took it back out cause of the theme switcher error (i dont use it)
Aah, ok.
jQuery’s…
Try to set to
$jsdir = "wxsim/jquery/";                           // js-folder
also the slash at the end
henkka
Ok this is strange, just added
$jsdir = “wxsim/jquery/”; // js-folder
and its still not right, just checked the sivu2.php as a test and thats showing the same,
see, i told you i wanted to be 1st that breaks it :wink: lol
Hi Henkka
Got it working:
www.silkeborg-vejret.dk/wxsim_allinone.php
Thank you very much for this great script. It has been a pleassure (as always) helping you testing.
Henrik
Just looked at your source-code, js-files are found ok, so also css-file.
But for some strange reason are the wind-dirs in charcters not numeric like this:
dirdata: [E,SSE,SSE,E,E,E,E,E,E,E,E,E,E,E,E,E,E,E,E,E,E,ESE,ESE,ESE,ESE,ESE,ESE,ESE,ESE,ESE,E],
Can you check they are numeric in lastret.txt? as they should be readed in “as they are” and that was the first error what FF’s errorconsole picked up for me.
henkka
I just changed it back to numeric, i prefer N E S W numbers confuse me lol its changed and uploaded as numeric now
I also changed from m/s to mph in the settings file but i aint sure if that was the correct place as its
still in m/s?
$uoms = array(’
Great, now its working :slight_smile:
The “m/s”-issue…
Aah… i see know forgot to add those, they are hardcoded to m/s #-o
Will fix that.
henkka
ok m8 no worries, Im going to call it a night, have to be up early tomoz, I will pick up on tomorrow
night, thanks for your help this evening, tis a great script, well done :slight_smile:
Fixed and zip updated.
changed files:
wxsim.allinone.plaintextparser.php
wxsim.allinone.lastretparser.php
jquery.wxsim.allinone.js
It now grabs it directly from plaintext.txt-file like plaintextparser “the orginal” do :wink:
Also added to sivu2.php a fix what hopefully fix that the tabs sometimes drops down below left sidebar (covered whole thing inside a table)
henkka
Great script , it looks amazing.
I’m in need of some help however if I could be pointed in the right direction please to fix the following.
I have the script setup at http://www.hayesweatherstation.info/sivu2.php
Detailed forecast is fine but hour by hour and meteogram are not showing data. Is there something i’ve missed?
Gray
Hi Gray
Where is your lastret.txt located? I think the meteogram and hour-by-hour use the data from lastret.txt. Detailed forecast use your plaintext.txt.
Check the paths for lastret.txt in the settings file.
Henrik
Hi Henrik,
Thankyou for the pointer everything is working now.
However it turns out that my paths in the end were ok but my lastret.txt is corrupt.
I borrowed another lastret.txt and it fired up ok so I need to go back and see how my text file differs from the working copy.
Many thanks for the reply this was the pointer I needed to track down the issue
Kind Regards
Gray
I,ve compared my lastret.txt with a working copy and I can see some differences such as decimal points and commas for temperature results.
Could someone please cast an eye over my non working version
http://hayesweatherstation.info/weatherdisplay/wxsim/lastretold.txt
For the script it should not matter are commas or points in use as it convert all commas to points anyway when it loop trought the file :smiley:
Henkka
Hi Hennka
Sadly im still struggling, I have used your updated files but for some unknown (to me) reason the weather icons
are not working for me this time lol
Heres what i have in the settings file…
// Icondir-paths (Yeah, we have 5 sets of them :D)
$iconDir =‘wxsim/img/dotvoid_frc/’; // Dotvoid icons
$iconDirb = ‘wxsim/img/dotvoid_mini/’; // Dotvoid mini
$bignumbdir = “wxsim/img/bignumb/”; // colorized numbers
$windarrows = “wxsim/img/arrows/”; // windarrows
$uvimg = “wxsim/img/UV_icons/”; // UV-icons
// jQuerydir-path
// Other paths
$pathtolsparser = ‘wxsim/wxsim.allinone.lastretparser.php’;
$lastretfile = “./lastret.txt”;
$plaintextFile = ‘./plaintext.txt’; // location of the WXSIM plaintext.txt
$filea = ‘wxsim/plaintext-parser-data.php’;
$fileb = ‘wxsim/plaintext-parser-lang-’.$lang.‘.txt’; // just change the path, language are detetcred auto
Hi all,
Nearly done, but condition icons aren`t there.
See: http://www.weerstation-marsdijk.nl/sivu2.php
Also I changed language in ‘nl’ but it isn`t translated.
Does it use they “old” “plaintext-parser-lang-nl.txt” file or do I have to translate everything again?
Any ideas or tips?
regards,
Oebel
Hello,
First part is solved. All icons are where they belong.
Only a question now about the translation. How is this simple to do?
Oebel
So long you have the path to plaintext-parser-lang-nl.txt correct it should use it directly, that was whole idea with the script, less translation-files. Note tought to add the new words from plaintext.lang.txt to it. Even if tryed to get all from old langfile it needed a few new words added to work smoothly :slight_smile:
Bashy,
humm…Have you checked the paths are correct? (ie. it looks for a icon what really exsists)
henkka
Hi Henkka
i try to run the perfect script - very good job.
But the script does not work correctly on my site.
I am not able to find the cause.
I see a message at the top of the page that is a problem with java.
But I do not know how to solve the problem.
I do not know if all of the error is associated with this message.
Maybe you have some hint
http://www.andretti.pl/wxsim_forecast.php
or
http://www.andretti.pl/sivu2.php
thanks
andretti
Edit:
the java error on my page say:
JAVASCRIPT STARTUP ERRORS
am is undefined at line number 8 in http://www.andretti.pl/wxsim_allinone/jquery/jquery.wxsim.flot.js
… please inform your webmaster.
Hi Hennka
The paths appear to be correct,
All the other icons work apart from the conditions icon/s
Andretti
In the settings file, do you have this path correct
$jsdir = “wxsim_allinone/jquery/”; // js-folder
I think yours should be as i have put above?
Hi Simon
I think that is good. Since all files are in subdirectory “wxsim_allinone” not “wxsim”
here my settings:
$iconDir ='wxsim_allinone/img/dotvoid_frc/';           // Dotvoid icons
$iconDirb = 'wxsim_allinone/img/dotvoid_mini/';        // Dotvoid mini
$bignumbdir = "wxsim_allinone/img/bignumb/";           // colorized numbers
$windarrows = "wxsim_allinone/img/arrows/";            // windarrows
$uvimg = "wxsim_allinone/img/UV_icons/";               // UV-icons
// jQuerydir-path
$jsdir = "wxsim_allinone/jquery/";                           // js-folder
// Other paths
$pathtolsparser = 'wxsim_allinone/wxsim.allinone.lastretparser.php';
$lastretfile = "lastret.txt";
$plaintextFile = 'plaintext.txt';       // location of the WXSIM plaintext.txt
$filea = 'plaintext-parser-data.txt';
$fileb = 'plaintext-parser-lang-'.$lang.'.txt';  // just change the path, language are detetcred auto
andretti
