Got fixed the issue with the paths on line 75-80 in xx.plaintextparser.php, are now in the settingsfile for easier setup (you still need to check the 2 paths ate top of that file tought).
henkka
henkka
Bashy,
Add that errorreporting(0); to the top of page too
Check the path to js-files, add a slash to $jsfile-settings (is “jquery” not “jquery/”?) as i saw it pushed out paths w/o that, also upload the jquery-files to that folder, seemed missing
henkka
OK, Error reporting added back in, i took it back out cause of the theme switcher error (i dont use it)
The files are in the jquery folder, e.g. public_html/wxsim/jquery
I have the jquery setting as
// jQuerydir-path
$jsdir = “jquery”; // js-folder
OK, Error reporting added back in, i took it back out cause of the theme switcher error (i dont use it)Aah, ok.
jQuery’s…
Try to set to
$jsdir = "wxsim/jquery/"; // js-folder
also the slash at the end
henkka
Ok this is strange, just added
$jsdir = “wxsim/jquery/”; // js-folder
and its still not right, just checked the sivu2.php as a test and thats showing the same,
see, i told you i wanted to be 1st that breaks it lol
Hi Henkka
Got it working:
www.silkeborg-vejret.dk/wxsim_allinone.php
Thank you very much for this great script. It has been a pleassure (as always) helping you testing.
Henrik
Just looked at your source-code, js-files are found ok, so also css-file.
But for some strange reason are the wind-dirs in charcters not numeric like this:
dirdata: [E,SSE,SSE,E,E,E,E,E,E,E,E,E,E,E,E,E,E,E,E,E,E,ESE,ESE,ESE,ESE,ESE,ESE,ESE,ESE,ESE,E],
Can you check they are numeric in lastret.txt? as they should be readed in “as they are” and that was the first error what FF’s errorconsole picked up for me.
henkka
I just changed it back to numeric, i prefer N E S W numbers confuse me lol its changed and uploaded as numeric now
I also changed from m/s to mph in the settings file but i aint sure if that was the correct place as its
still in m/s?
$uoms = array(’
Great, now its working
The “m/s”-issue…
Aah… i see know forgot to add those, they are hardcoded to m/s #-o
Will fix that.
henkka
ok m8 no worries, Im going to call it a night, have to be up early tomoz, I will pick up on tomorrow
night, thanks for your help this evening, tis a great script, well done
Fixed and zip updated.
changed files:
wxsim.allinone.plaintextparser.php
wxsim.allinone.lastretparser.php
jquery.wxsim.allinone.js
It now grabs it directly from plaintext.txt-file like plaintextparser “the orginal” do
Also added to sivu2.php a fix what hopefully fix that the tabs sometimes drops down below left sidebar (covered whole thing inside a table)
henkka
Great script , it looks amazing.
I’m in need of some help however if I could be pointed in the right direction please to fix the following.
I have the script setup at http://www.hayesweatherstation.info/sivu2.php
Detailed forecast is fine but hour by hour and meteogram are not showing data. Is there something i’ve missed?
Gray
Hi Gray
Where is your lastret.txt located? I think the meteogram and hour-by-hour use the data from lastret.txt. Detailed forecast use your plaintext.txt.
Check the paths for lastret.txt in the settings file.
Henrik
Hi Henrik,
Thankyou for the pointer everything is working now.
However it turns out that my paths in the end were ok but my lastret.txt is corrupt.
I borrowed another lastret.txt and it fired up ok so I need to go back and see how my text file differs from the working copy.
Many thanks for the reply this was the pointer I needed to track down the issue
Kind Regards
Gray
I,ve compared my lastret.txt with a working copy and I can see some differences such as decimal points and commas for temperature results.
Could someone please cast an eye over my non working version
http://hayesweatherstation.info/weatherdisplay/wxsim/lastretold.txt
For the script it should not matter are commas or points in use as it convert all commas to points anyway when it loop trought the file
Henkka
Hi Hennka
Sadly im still struggling, I have used your updated files but for some unknown (to me) reason the weather icons
are not working for me this time lol
Heres what i have in the settings file…
// Icondir-paths (Yeah, we have 5 sets of them :D)
$iconDir =‘wxsim/img/dotvoid_frc/’; // Dotvoid icons
$iconDirb = ‘wxsim/img/dotvoid_mini/’; // Dotvoid mini
$bignumbdir = “wxsim/img/bignumb/”; // colorized numbers
$windarrows = “wxsim/img/arrows/”; // windarrows
$uvimg = “wxsim/img/UV_icons/”; // UV-icons
// jQuerydir-path
// Other paths
$pathtolsparser = ‘wxsim/wxsim.allinone.lastretparser.php’;
$lastretfile = “./lastret.txt”;
$plaintextFile = ‘./plaintext.txt’; // location of the WXSIM plaintext.txt
$filea = ‘wxsim/plaintext-parser-data.php’;
$fileb = ‘wxsim/plaintext-parser-lang-’.$lang.‘.txt’; // just change the path, language are detetcred auto
Hi all,
Nearly done, but condition icons aren`t there.
See: http://www.weerstation-marsdijk.nl/sivu2.php
Also I changed language in ‘nl’ but it isn`t translated.
Does it use they “old” “plaintext-parser-lang-nl.txt” file or do I have to translate everything again?
Any ideas or tips?
regards,
Oebel
Hello,
First part is solved. All icons are where they belong.
Only a question now about the translation. How is this simple to do?
Oebel
So long you have the path to plaintext-parser-lang-nl.txt correct it should use it directly, that was whole idea with the script, less translation-files. Note tought to add the new words from plaintext.lang.txt to it. Even if tryed to get all from old langfile it needed a few new words added to work smoothly
Bashy,
humm…Have you checked the paths are correct? (ie. it looks for a icon what really exsists)
henkka
