Thats cured the language side of it thank you… still gettting langaue errors though and i think theres
been a needle found in the haystack, whatever that means pmsl…
Got fixed the issue with the paths on line 75-80 in xx.plaintextparser.php, are now in the settingsfile for easier setup (you still need to check the 2 paths ate top of that file tought).
Add that errorreporting(0); to the top of page too
Check the path to js-files, add a slash to $jsfile-settings (is “jquery” not “jquery/”?) as i saw it pushed out paths w/o that, also upload the jquery-files to that folder, seemed missing
Just looked at your source-code, js-files are found ok, so also css-file.
But for some strange reason are the wind-dirs in charcters not numeric like this:
dirdata: [E,SSE,SSE,E,E,E,E,E,E,E,E,E,E,E,E,E,E,E,E,E,E,ESE,ESE,ESE,ESE,ESE,ESE,ESE,ESE,ESE,E],
Can you check they are numeric in lastret.txt? as they should be readed in “as they are” and that was the first error what FF’s errorconsole picked up for me.
ok m8 no worries, Im going to call it a night, have to be up early tomoz, I will pick up on tomorrow
night, thanks for your help this evening, tis a great script, well done
Thankyou for the pointer everything is working now.
However it turns out that my paths in the end were ok but my lastret.txt is corrupt.
I borrowed another lastret.txt and it fired up ok so I need to go back and see how my text file differs from the working copy.
Many thanks for the reply this was the pointer I needed to track down the issue
// Other paths
$pathtolsparser = ‘wxsim/wxsim.allinone.lastretparser.php’;
$lastretfile = “./lastret.txt”;
$plaintextFile = ‘./plaintext.txt’; // location of the WXSIM plaintext.txt
$filea = ‘wxsim/plaintext-parser-data.php’;
$fileb = ‘wxsim/plaintext-parser-lang-’.$lang.‘.txt’; // just change the path, language are detetcred auto
Also I changed language in ‘nl’ but it isn`t translated.
Does it use they “old” “plaintext-parser-lang-nl.txt” file or do I have to translate everything again?
