create a yowindow
Hello
I have a weather station oregonscientific Weather Station WMR200
and I use the program Weather Display
how do I create a yowindow.xml file.til Weather Display
so I can run my way station on yowindow
Yours, Steffen
You need a recent version of WD, then the create yowindow.xml is on the drop down list on setup tab.
Hello
whatโ€™s the version I need to do yowindow.xml
you thanks for your help
Yours, Steffen
Hello
I can not find the place where I do yowindow.xml
you can not write a little more closely at where I have to do it
Yours, Steffen
Just download the latest version from Weather Display - Downloads
then tick this option:
Hello
I have just one question
I have set my weather station to run on yowindow
but nothing happens on the display
what could be wrong
Yours, Steffensteffen
have you set WD to upload the needed file and set yowindow to use that file as the data source?
Hello
no I have not tried to do
you can not make a description how
inside the weather display puts yowindow up so you can retrieve data
from its weather station and look them up on yowindow
Iโ€™m new here so I know not so much for weather stations
Yours, Steffen
have you set for the yowindow to upload to your web site?
(and do you have a web site,and if you do, do you then have the ftp settings for that set in WD, in the connections setup (and then main internet switch on there)
hello again
I have no home page but I will no be made
I shall just have done so I can run the data set of weather station and yowindow
so I can look at yowindow on my PC the weather
I would like to know you do it
Yours, Steffen
you would need to get the author of yowindow to be able to read the data file created by WD on your pc
It will as was explained to Steffen here http://yowindow.com/forum/viewtopic.php?f=14&t=824#p3107.
  • Jim
cool, makes sense that it can do that :slight_smile:
